- Dec 27, 2013
Hey guys. I recently got a big pile of birdseye figured black and white ebony in from Laos, and they are nearly completely green. So i figured it was time to set up a drying apparatus.
The physics of safely drying wood are, to put it simply, complicated. Its not as simple as saying a kiln dries wood more safely than air, or that high heat is more dangerous for wood than low humidity, its complicated. Im using a mix of sources, but the work by Gene Wengert is invaluable. https://www.wagnermeters.com/moisture-meters/wood-moisture-training/wood-doctor-videos/
http://www.lignomatusa.com/wp-content/uploads/2015/02/DryingLumber.pdf
I dont pay for power at my workshop, so i will be using a closed system removing all the water with a dehumidifier. This will be more power intensive, but should give me more control.
I will only post the rough outline of my plans on bladeforums, since i would hate to accidentally mention that i sell wood and get accused of ruining this forum again, so if you want to keep track of this project in a more detailed way, or to see my measurements, laser cut files, or the data i collect for safe drying rates of exotic woods through a series of tests, all of that information will be on my website.
Put simply, i will be using a converted 72 x 48 x 18 inch cabinet with a set of fans, heaters and a dehumidifider controlled by a PID humidistat. By keeping the system sealed instead of using a constant inflow and outflow, i should be able to better measure the rate of moisture loss, as I can weigh the mass of the water removed against the weight of wood i started with to calculate the % of moisture it represents.
And here is what will be going in the kiln for its first runs
