- Apr 17, 2007
OK, I know you guys are some crafty fellows, so I need some help. I was at Cumberland Island the past few days and have become fascinated with finding shark teeth. My wife and I found probably 50 during a couple of days of occasional searching, mostly finding them on the roads since they use dredged material to "pave" the roads. We even found a few broken pieces from megalodon teeth. I'll post a trip report tomorrow.
I talked to a ranger who said that just walking along the roads looking for them is good, but going to the dredge piles and using a sifter is even better. I have seen sifters for sale and plans for sifters all over the Internet, but the big, bulky ones don't really do it for me. I want a badass, lightweight, portable sifter.
I am thinking of using some angle aluminum to create a frame, connecting it at the corners with bolts and wing nuts so it can be assembled and disassembled quickly and easily.
I want to have a couple different layers at least, and the only thing I can think of for the sifter surface is hardware cloth. I would really like something more portable than that, since you can only really roll hardware cloth because bending it will eventually stress it enough to the point where it breaks. I have some Kevlar string from County Comm that I was thinking I could weave into a couple net type surfaces with different sized holes, but I was not sure if that would be durable enough. Also, I have not messed with net weaving a whole ton, so hopefully Doc Canada sees this thread and takes interest.
Between the layers, I was going to have some short aluminum tubing connected by screws just to keep the layers a bit apart. The whole idea is to be able to collapse this thing and stuff it in a backpack. I can add some pipe insulation if I ever need it to float.
So, what do you guys think? Any good ideas for a durable net surface? It will have to withstand repeated sharp edges and constant sand abrasion. I need some redneck engineering help!
Edit: Here are some pics of the teeth I gathered:
