- Jul 23, 2015
Forge size: 10"x 18"
Chamber size: 6"x18"
Burner type: propane ribbon
After spending a ton of time researching, designing, and getting input from friends, I decided to build my first forge. I still need to make some minor changes but I got the body built, lined, and the first coat of satanite on. The body is 16 ga 304SS that I rolled into 10" diameter. The feet are 10ga 304 plates, and 1x1x18" 304 angle. Everything was tig welded. I haven't finalized what I'm going to do for doors yet. I did 2-1" layers of kaowool. I didn't have enough time to finish my burner. I am hoping I can cast it tomorrow. I'll update with progress.
Rendered my parts in solidworks, then cut them out on the waterjet. The Q looking piece is a choke plate.
Starting to roll the body. This took a while as the roller is rated for 16ga steel, not 16ga stainless.
Body all welded up and my "too small"burner plenum. I had hoped to build everything completely out of stainless but couldn't source a tapered tee fitting in stainless so I ordered a ward tee.
Base all fit and tacked.
First lining.
First lining.
