- Jun 11, 2006
I have relized I need a dedicated tempering oven. Not looking to take on a huge project like my heat treat oven build. This leads me to ask for your advice on what you think.
My thought is to insulate a large air tank and use a heat source with a blower to pump the air into the chamber. This would be wired up to a SSR and a pid with a TC. I have a few tanks that I think would work well and would be simple to modify. My first thought was to use say a 2" Diamater black pipe ran along the roof of the tank. The pipe would stick out the rear of the tank. Inside the tank this pipe would have holes along its length pointing to the left or right. I then would use somthing like a heat gun stuck into the pipe and wired up to the SSR. I'm thinking I would re-wire the heat gun so I can control the element and blower separate. Maybe keep the blower on and cycle the element on and off. I would insulate the outside of the tank and put this inside another tank. Of corse I would need a vent of sorts to allow the blown air back out without to much back pressure. The vent could just be a series of holes through the inside tank and let the air vent through the insulation and out a few holes in the side of the outer tank. The floor of the tank could be horizontal metal bars going from one side to the other like a grill grate. This would allow the air to circulate around the blade and create an even heating. By not having any exposed elaments I would eliminate IR problems.
Here are the two tanks I'm thinking about using. The blue one is 11" by like 22" the red one is bigger which would allow for plunty of insulation. The picture of the air compressors is just to show the tank. I have another compressor just like it that has a rusted pin hole in the tank and has been retired for parts. I would use that tank.
Let me know what you think. I know it's kinda hair brain and off the cuff but I need something better then a toaster oven and I hate waiting for my big heat treating oven to come down in temp.
