- Mar 12, 2013
I've been thinking about switching over to 'stonewashed' finishes for a long time, I think it makes a lot of sense for me given that I'm making working knives. I've finally decided to pull the trigger after seeing photos of Daniel Fairly's stonewashed blades the other day, which look absolutely gorgeous!
I've been researching this for a while as well, and unfortunately there don't seem to be any commercially made tumblers that are really the size I'm after. The tumblers from C&M Topline seem very well made (and Dan Lord is a really nice guy!), but their largest 'doughnut' tumbler (the TLV75) is too small to fit a kitchen knife or larger fixed blade, and their next step up is positively huge, weighing in at 400lbs!
My plan is to design and build a tumbler sized in between those two, at around 1 cubic foot capacity. The design overall will mimic the 'Mr Deburr' units that C&M Topline sell:
The tub and base will both be welded assemblies, this is a perfect project for me to learn to weld which I've been meaning to do for a while! The tub will likely be made from 16GA or 14GA cold-rolled steel sheet, with a polyurethane liner of some sort cast in place inside. The tub will be reinforced with angle steel along the edges and a plate along the bottom for mounting the oscillating mechanism.
Underneath the tub there is a pair of pillow blocks supporting a jack-shaft that holds the offset weight that provides the oscillation in the tub. The jack-shaft is connected to the motor by means of a v-belt and pulley. The motor is attached to a hinged plate and it's weight is what keep the belt tight.
The springs that isolate the tub from the base are my main question mark right now, I'm sure I can use something like die springs, but I'm not yet sure how I'll attach them to the tub and base.
The motor will be a 1725RPM 3/4HP 115V single phase TEFC motor, with a simple magnetic starter for safety.
I'll be posting a full BOM and drawings so that others can build one too if they so desire, hopefully it turns out well. I'm putting a bit of a rush on this project as I'd like to use it for my next batch of knives!
If anyone has photos of the jack-shaft assembly from a Mr Deburr unit I'd love to see them, I need some inspiration on how to make the weight assembly that attaches to the jack-shaft!
-Aaron
-Aaron
