okay, details:
1/8 inch (.119 nominal) 15N20 steel with a full quench and a differential temper. I leave the forge finish on the flats with most blades of this and related types, just make some passes on it with 400 grit to smooth it out.
Grind is a convexed scandi grind, scandivex, taper, whatever anyone wants to call it.
The handle is fairly beefy, with lots of room for adjusting grips and little bits of filework here and there for indexing on. The integral guard formed by the handle scales is fileworked on the bottom. I often place a finger there when doing fine work.
Scales are micarta, caramel colored. Pin stock is stainless tubing, with plenty of attachment options for lanyards.
Spine is mostly straight for scraping and broad enough to grip with your hands when needed. The straighter spines are also nice for batoning. I did a bit of cross hatching on the spine for easier firesteel work.
The sheath is the explorer model- made by me. I included two belt hangers, one is the traditional type with the chicago screws (thread lock them as needed). The other is a wider one meant to be tied closed. I included some light "220" cord for that purpose.
There's not much else to say about the knife itself. My process, as usual, was to let it grow in my hands. (or shrink, whatever.) I knew that we'd be dealing with colder temps some of the time (here in the Great Basin as well as off in new england) and wanted to increase the handle size for glove work. I also made sure the guard section was beefy enough for frozen finger safety. The balance is very much centered on the handle, back with the index and middle fingers, for fine handling.
I rarely use patterns, and when I do it's as a visual reference. Each knife gets done and balanced in my hands as I work it. Grinds are similar. Most blades like this have a slightly variable convex grind, with a section of steeper angles at the base and a steeper final edge angle at the tip.
The particular model is named the "Great Basin Bushcrafter". The basin is a very interesting section of the continent with restricted watersheds (they drain inland and not to the seas), washboard ridges and ranges mostly running north/south, and a wide variety of climate zones in very abruptly changing sections.
One example is coming off of a peak into the Basin from the san bernadino mountains- where you can ride a tram through 5 major climate/environment zones in less than 45 minutes. 3 days easy light hiking. You need a knife built for the whole range, with the normal understanding that you don't tend to have the dense, wet forests of the PNW and southeastern US. Pine scrub, cattails and roses along the creeks, high desert, some deciduous oak and walnut foresting, plains-like flats, and such.
