Busse Sword Help Identifying???
Can you identify this busse blade? It has 22" Blade and a 10" Handle. The only difference is it has a tanto tip which I cannot find and info on.tantobussesword.jpg
Something along the lines of ruck force 1. I think they were part of operation two weeks or a ganza last year.
Blade is longer on yours. Than a ruck force one. Is the blade chisel grind?
He is asking if the edge bevel is on one side of the blade only, vs ground on both sides. For right hand use, that would mean the right side (hidden from view in the photo) has the edge bevel, while the left side is basically flat (or concave even)
It has a lomger handle than the rucki. It was a special release. It is based on the AK blank wirh rhe tip and tail modified. Asking on the Busse subforum will get you an answer. Some one has already postes one and asked this question, if i am not mistaken.
