- Jun 2, 2011
Sal has stated that SE H1 outperforms (at the time) any steel they use on the CATRA.What scientific data supports this assertion or is this just your personal opinion? Can you provide a link?
I'd get the plain edge in an Endura and a Pacific Salt for a serrated edge.
I'd skip the combo edge.
Why do you all recommend the H1 for SE over the VG-10?
It all depends on your cutting needs, but if you haven't tried a fully serrated Endura, I'd say give one a try. I think you'll be blown away with how well it chews through everything in its path.
Decided to go with the Pacific Salt serrated, thanks for all the input!
Never SE for me, I'm aware it's great for sawing or hacking through tough stuff but it's Greek to me. I love slicing with little effort using my razor sharp pocket toys.
Lance, are you using the Sharpmaker to maintain the edge on your SE Pacific Salt? Mine is sharp, but not tree topping. If your answer is yes, then I know I need to hone (!) my SM skills.
I too prefer a pe for 90% of my cutting chores, but I do appreciate a se knife at times. As far as the edge, it is extremely easy to maintain a se on the Sharpmaker. It makes a big difference if you do regular "30 second" touchups and never allow the knife to get really dull. I used to avoid se knives because I was afraid I would struggle to keep them sharp. Once I got the sharpmaker and watched Sal demonstrate how to do it on the dvd I gave it a try and realized my concerns were entirely in my imagination. As I mentioned earlier, i use a little different technique than he demonstrates and I get really good results. Here is a copy and pasted explanation I made in another thread if anyone is interested.
Serrated Edge:
Fine rods in the 40 degree slots. Three passes on the serrated (left) side pulling straight down like normal. Then 2 very light passes on the back side. When working the back side, tilt the knife so it is almost flat with the rod...about 5 degrees instead of the 20 degree angle you would get if you pulled straight down. Repeat until sharp. Thats pretty much it. One tip is you want to go fairly slow and keep the pressure fairly light so that you don't "jump" the serrations. If you go too slow it doesn't work....too fast either. There is a certain speed at which the rod will smoothly enter and sharpen each of the individual serrations as you pull the knife down. It will be pretty obvious once you are doing it and have a tactile feel for it.
Just wasn't into the Pacific Salt SE...It's up for sale.
