Cyrano
- Jun 13, 2015
When I use my WorkSharp Ken Onion with Blade Grinding Attachment to re-profile a blade, I don't obsess about the absolute value of the edge apex angle. As long as the final edge is sharp and in the right ballpark for angle, I'm happy; I don't care much whether the apex is 30 degrees inclusive or 35 degrees inclusive.
When I use the tool to touch up an existing edge, it's a different story. I know from experience that if my sharpening angle doesn't match the existing edge apex angle, I'm going to have trouble:
The experiment consisted of sharpening ten 20-gauge steel strap ties:
I was surprised and delighted to get such clean results.
I know from experience that even slight changes in blade orientation with respect to the belt (in pitch, yaw, or roll) can cause big variations in the geometry and variability of sharpening results. Thus, I don't believe the absolute values of my results are directly applicable to any other user of this tool.
What might be true about the tool itself, and thus applicable to other users, are these observations:
- If the tool is set to an angle significantly more acute than the existing apex angle, I'm going to remove a lot of steel, and broaden the edge quite a bit, before my sharpening hits the apex.
- If the tool is set to an angle significantly more obtuse than the existing apex angle, I'm going to form a double-bevel edge. The resulting edge might work OK or not, depending on the specific circumstances, but it's not what I want to achieve.
- Five of the samples were sharpened using a coarse WorkSharp standard belt, at angle settings of 10, 15, 20, 25, and 30 degrees.
- The other five strap ties were sharpened using a coarse WorkSharp extra-stiff belt, at the same five angles.
- All ten samples were de-burred using a WorkSharp linen stropping belt with Dialux green polishing compound.
- All ten samples were then measured for apex angle.
- The results for the standard belt show a much better linear correlation than I would have expected, given the number of uncontrolled variables I create when using the tool.
- The results for the extra-stiff belt form nearly a perfect linear relationship. Had I not done this work myself, I'd say these results are too good to be true, and were fabricated by the investigator.
- There is a good linear relationship between the tool setting angle and the resulting edge apex angle. This means the tool is well-behaved, and can deliver consistent results.
- The linear relationship does not intersect the origin (x=0, y=0). This means one should expect an offset between the tool angle setting and the actual edge apex angle.
- There is more variability (i.e., weaker linear correlation) for the standard belt than for the extra-stiff belt. This might be expected, as a more flexible belt might translate more variation in blade-to-belt pressure than would a stiffer belt.
