California Dirk or Dagger "Morality"
rb1
California Dirk or Dagger “Morality"
In keeping with my experience that California criminal laws always get more convoluted instead of simpler, the California Second District Court of Appeal quietly slipped a stunning case into the appellate record during the pandemic: People v. Hester (2020) 58 Cal.App.5th 630. This case is primarily a “dirk or dagger” case as it elucidates California Penal Code sections 16470 and 21310, which deal with “concealed carry” of a “dirk or dagger” under California state law. The twist is that the Court of Appeal here added a “morality” component to the possession of a concealed “dirk or dagger”. The opinion also blurs the line between the definition of a fixed blade versus a non-fixed blade “instrument that is capable of ready use as a stabbing weapon.” The kicker is that the court here found that a standard boxcutter qualifies, in some circumstances, as an illegal dirk or dagger. Yep, you read that correctly. Now you have to worry about a hardware store boxcutter being a dagger in California.
Before I get deep into the details of this crazy case, let’s talk a little bit about California legally carried dirks or daggers. The basic rule in California is that fixed blades of about any style and length (including double-edged long swords) are perfectly legal to carry in California if they are NOT concealed. In fact, walking around Witcher-style with a large double-edged sword is likely to be perfectly fine in California. For example, this should be OK:
However, according to People v. Hester, if you have one of these buried in your pocket, you’re potentially in some trouble:
Hester is arguably an anomaly, because it involved a defendant who not only had strike priors under the California 3-strikes law, but also because there was some evidence that he shanked a dude with one of his boxcutters. Hester is also a rare published criminal decision, it is not a California Supreme Court case, and there are other California Court of Appeals districts which are not bound by Hester, so there is some possibility it gets clarified, distinguished or overruled later.
The basic facts of Hester indicate that Mr. Hester was carrying two box cutters, both with a blade of about one inch. That would automatically exclude them from the “switchblade” category in California because Penal Code section 21510 only prohibits “switchblades” with blades that are “two or more inches in length.” Because of this, the Hester court goes out of its way to define a standard boxcutter as a “dirk or dagger”. There are no pictures of the two boxcutters in the Hester opinion. One, which was found in his “right pocket”, is described as “a folding box cutter that locked into place when opened.” No description is given of the kind of lock. It apparently had a “button on the handle” which, when depressed “the blade slid open and locked into a fixed position.” In order to close it, the button had to be depressed again.
The second box cutter, which was found in a backpack he carried, is described as a “’non-folding box cutter’ that had a button to slide the blade open and which locked the blade into place.” Oh, and yes, carrying concealed in a backpack is carrying concealed on your person.
Apparently, Mr. Hester’s attorney(s) did not argue that either knife was non-locking or was a pocketknife. Either of these arguments would have potentially excluded it as a dirk or dagger under California Penal Code section 16470. There is also (an apparently not raised) argument that one or both qualified as what section 16470 describes as “a folding knife that is not prohibited by Section 21510.” It’s not clear whether the defense hired an expert. I would not concede these points if I were defending somebody in this instance. But I also think the Hester court overreached here in defining these boxcutters as dirks or daggers.
Which brings me to the next problem with the Hester opinion. The evidence in the case seems to indicate that when these knives were found they were closed and the blades were not exposed. That’s probably true, because who carries an open boxcutter in their pocket? The court doesn’t explicitly indicate what the finding at trial was on this point (pun possibly intended.) If I had to do a trial on this, I would ask for an explicit jury finding about whether the knife was carried in an open and fixed position while concealed. In this case, Hester waived jury and had a court trial only. Another seriously questionable defense tactic on a felony case. In any event, the chief problem here is that section 16470 expressly indicates that a dirk or dagger is only “capable of ready use as a stabbing weapon” if “the blade of the knife is exposed and locked into position.” It would seem that wasn’t the case here. But the Hester court seems to have conveniently ignored this seemingly important qualification. (I should add that I question whether either of these knives truly qualify as “stabbing” instruments, a point I would not have conceded (pun possibly intended again.) Just because they will cut doesn’t mean they will stab.)
In People v. Castillolopez (2016) 63 Cal.4th 322, the California Supreme Court clearly stated that a folding multi-tool was NOT a dirk or dagger because the blade was not locked into position. Without getting deep into the appellate weeds here, I can say that a review of California cases on this topic, and Castillolopez in particular, suggests that a folding knife with ANY kind of a locking mechanism could potentially qualify as dirk or dagger in California simply by virtue of having a locking mechanism. My contention would be that the knife has to be FOUND in an open and locked state to qualify. The case law is unclear. However, the definition of “switchblade” in Penal Code section 17235 expressly excludes knives (ostensibly folding) that have a detent or “other mechanism that must be overcome in opening the blade, or that biases the blade back toward its closed position.” Obviously, some types of folding knife locks would fit this latter definition.
So the question remains, is ANY folding and locking knife going to be considered a “dirk or dagger” in California simply by virtue of the fact that it has a locking mechanism? That should worry just about anybody in California who carries a pocketknife in, well, a pocket. Buck 110s are illegal in California under this theory if you put them in your pocket.
Which brings me to the final point about Hester. Morality. The concurring opinion (not a dissent, but still a rarity for a Court of Appeal case in CA) went to great lengths to point out that the 2-judge majority opinion could mean that everything from pencils to screwdrivers and from sewing needles to miniature Eiffel Tower replicas qualify as dirks or daggers. It also indicated that there are overwhelmingly legitimate reasons for people to be walking around with boxcutters. Like, maybe they work in a grocery store. To quote, “it should raise eyebrows that an ordinary box cutter is an illegal dirk or dagger.”
Ultimately, despite being a questionable opinion, the Hester court maybe did the average California knife carrier a favor. They levied a “morality” requirement: “this holding that box cutters are dirks or daggers is right only if we read the statute to ensure it cannot condemn morally blameless people.” In other words, you better be able to prove you were carrying it for some reason other than shanking a dude. Top Chef contestants can now breathe a sigh of relief when they are running around Los Angeles with their fixed-blade "capable of ready use as a stabbing weapon" instruments concealed neatly in their cases:
Moral of the story (yes, pun possibly intended again). Why might you be carrying a knife in California and be “morally blameless”? Chef? Painter? Construction? Gardening? Box or letter recipient? Cosplay? Historical recreationist? Bushcraft? Picnic? Actor? Collector? I’m sure some other people could list a host of other reasons. Discussion encouraged. Just make sure if you shank a dude, it’s in defense of your person or another person. I also encourage taking the 5th and asking for a lawyer if arrested.
-rb
It's obviously stupid, but the statute defining "dirk or dagger" is stupidly written and absurdly vague. I do think "not morally blameless" was something of an understatement based on the fact that the defendant in Hester had slashed someone with a box cutter and was threatening to "f'in do it again, I'll kill you," and also threatened the eyewitness ("Who are you, bitch? I'll f'in kill you") who approached the victim after she heard him calling for help. If you're looking for guidance in this decision as to "morally blameless" these facts are probably rather important. The court also listed examples of "morally blameless" people such as grocery store workers, carpenters and car mechanics.
You make excellent points. I will say that once courts start defining intent as "morally blameless" that begins the roll down a slippery slope. In this particular case, the facts are pretty stark, but I can envision self-defense cases where these distinctions are much harder to draw.
Carrying a folding knife in the exposed position in your pocket with Cali prosecutors. A few years ago a fellow was convicted because he had an open SAK in his pocket. It was eventually overturned but I"m sure it wasn't fun for him.
If only there was a reasonable way to carry your folding knife in your pocket. Could be a million dollar idea for anyone who solves the puzzle.
I read the Appeals Court decision on People v. Hester when it first came out (I'm a 52 year resident of California).
1. It's a bonehead decision (defining box cutters as "dirks" and "daggers").
2. At first glance it gives cause for concern by expanding the definition of "dirks" and "daggers", but the specifics alleviate my concerns- 1. as already mentioned, Mr. Hester was a scumbag criminal, which heavily influenced the judges decision. 2. As fonedork mentioned above, the judges specifically mentioned in their decision that persons carrying concealed box cutters for legitimare reasons should NOT be prosecuted.
As someone who carries concealed folding knives in California, I'm not worried about People v. Hester.
Prosecutors have ALWAYS tried to expand the law in their favor, and they always will. Sometimes they succeed, sometimes they don't. And sometimes judges make bonehead decisions. Neither of those things is ever going to change. That's life.
I remember when prosecutors in California used to prosecute one-hand opening folders as switchblade/gravity knives because they could be flicked open. But they lost that one. And now the law specifically exempts such knives from the switchblade/gravity knife definition (CA penal code 17235), as long as they have a detent or other mechanism that biases the blade in the closed position. That was a BIG win for knife owners in this state.
This is terrible jurisprudence, as noted, in part, by the concurring opinion.
The issue isn't Hester, who is most likely a criminal. The issue is that the case sets precedent about what may be legal or illegal to carry. People should be very cautious about laws that can be selectively applied because a potential defendant is viewed as a "bad guy." Further, being able to raise "moral blamelessness" as a defense to a charge is not how the system is supposed to work. As noted by the concurring opinion, perhaps sarcastically: "The approach that “common things are illegal but you may defend by showing you are innocent” may clash with more recent Supreme Court notions about the burden of proof in criminal law."
I do think that the "pocketknife" exception is perhaps some comfort here. The court would have a difficult time using its stated reasoning if, e.g., Hester was carrying a Buck 110 (provided it wasn't open). But this exception illustrates the absurdity of the law: by the court's reading, PC 16740 would potentially criminalize carrying scissors in your pocket but not the "Stabby McShiv Self-Defense Pocketknife, (with serrated bloodgrooves)."
Especially if your Stabby McShiv has tsuchime and a hamon.
But seriously, I agree with your analysis about the burden of proof, because that's really the downside of this case. It essentially creates an affirmative defense and shifts the burden of proof to the defendant, forcing a defendant to prove they are not a "scumbag." That isn't how the criminal justice system should work and, frankly, nobody should want it to work that way. Sometimes there's a fine line between one person's definition of scumbag and another's definition of righteous defense. If you ever have to draw that Stabby McShiv in self-defense, you might be in a tough legal spot even if you are in the right. A hypothetical scenario is to take the facts of Hester case but what if the independent witness only saw the end of the fight and not the beginning, and the "victim" was the initial aggressor. That scenario sometimes happens in the real world.
Yes. To be clear, I was merely pointing out the absurdity of criminalizing scissors, when a pocketknife designed for stabbing people would be legal. I wasn't even contemplating your self-defense scenario (which is absolutely legitimate).
Here is another hypothetical: you are carrying a Chaves CHUB flipper (or a small utility knife) in you pocket, because it is a handy tool. For instance, to open envelopes, break down cardboard, or for any number of things that may come up in a day. You are walking down the street and a cop stops you because he doesn't like the look of you (maybe your are wearing a Pantera hoody, and the guy likes Barry Manilow), and he finds your tool. You are charged with a crime. You claim you are carrying the tool because it's useful, not to stab someone AND THE COURT DOESN'T BELIEVE YOU.
Any knife guy that has had to try to explain to, e.g., an aunt at Christmas dinner why they carry a folder and "secondary" should be very nervous about justifying your choice in knife carry to non-knife people when criminal prosecution is the penalty.
  • Like
Reactions: rb1
Exactly. This is the exact problem with this case. They've essentially criminalized an entire classification of otherwise legitimate carry knives and pushed it onto the user to prove they didn't have criminal intent. Now it's down to luck of the draw on prosecutors, judges and juries. Not necessarily a situation anybody wants to be in. Truth be told, I think unless you are actively committing a crime or you actually use a knife in a fight, odds are you aren't likely to be arrested for knife possession in California, much less successfully prosecuted (unless maybe you're a juvenile). However, this case does generate some real concerns.
(edited for grammar)
It seems to me that the 'morally blameless' point is a restriction on the state's use of this law against people unless they were doing some inherently criminal act, such as assaulting or robbing people, and not that all of us had better goddamned well get our story straight when we leave the house. I like that the court didn't do what my and likely many other states have done, and exclusively use fish and game-related examples, which muddied the waters for decades on our knife laws. Really the 'hunting, fishing, and trapping' cited in the original laws were just examples of the kinds of general activity that legal knives might be useful for, in opposition to daggers, dirks, stilettoes and other prohibited knives, which will by design be ineffective and clearly not intended for such ordinary chores and activities.
The charge does not require some further crime. Just carrying would be criminal.
The way such issues are charged and prosecuted makes it unlikely that some guy carrying a pair of scissors is convicted, but that is based on practical considerations, not legal requirements. It does not mean people should be unconcerned.
I think this was the primary issue that they got wrong:
“Neither box cutter was a nonlocking folding knife. Defendant concedes that both box cutters locked into a fixed position when open and therefore do not qualify as nonlocking knives. The box cutters obviously were not pocketknives, and defendant does not contend they were.”
That last sentence is the problem imho. The defendant SHOULD have contended that closed box cutters WERE pocketknives. Why wouldn’t they be??
Yeah this is a disturbing case for sure. :(
I agree. They conceded points they should not have conceded. Reading between the lines here, particularly given that the defense waived jury in this case (a phenomenally bad idea in a California felony case), my guess is that the defense figured they would win on this issue. The knife possession count was an extra count on top of other more serious charges. They probably thought they would win on this count, and, honestly, there was no precedent that this kind of knife would be illegal to possess here, so they clearly didn't fight too hard. Also, when waiving jury, you are really totally at the mercy of the judge so it helps not to piss off the judge, and sometimes conceding things that would otherwise be contestable wins brownie points with judges. The other crazy thing here is that this case even ended up as a published appellate decision at all. That's vanishingly rare in California these days. It's really a combination of errors, bad judgment, bad facts, bad luck, and bad legal analysis that led to this decision.
I hate how vague the laws are. My interpretation of things, in LA county, is this. I can't carry a fixed blade at all, no way, no how, because the county law says I must conceal the blade and state law says I must wear it openly. Take your pick, which law do you want to break? Folders - no limit on size, no automatic, no balisong, and I don't mess with springs just because I don't trust a cop to be able to tell the difference. I was under the impression that any knife becomes a chargable "offensive weapon" if you commit a crime with it, that is why the law says something about offensive weapons with the description of any knife attached. I like large carry, and almost every day I am sporting at least one folder that is between 4" and 7.5". I sometimes am afraid that a police officer would see my Espada XL, or my Voyager XL, or even an Endura or a Yojumbo, and confiscate it for being "too big" for their liking.
Following the rules of stupid has helped me immensely. Don't go stupid places, with stupid people, at stupid times, to do stupid things. I haven't had a single police encounter since I started following those rules after my teens. I still have fear, because I am a young person and I am not an established member of my community. I am afraid that assumptions would be made about me if I ever had to defend myself. The vague laws do not help.
If this scumbag criminal, with a history of shanking and threatening people with his boxcutter (or even a screwdriver or Bic pen) had been locked up for life for attempted murder where he belongs, his misbehavior wouldn't be threatening our knife rights.
Do we want him for our knife rights poster boy, or do we want him imprisoned as an example of unacceptable, violent, deadly behavior?
Californians need to elect law and order politicians instead of blaming innocent tools.
So, in California, a folding pocket knife with only the clip showing is considered "openly" carried
But a fixed blade in a pocket sheath with the clip showing, part of the sheath showing, and part of the handle showing, is considered "concealed" carry?
L O effing L!
L O effing L!
I don't think a clip is a real problem, I wear a clip all the time. If you want to be safe from any cop that is extremely overzealous, then you can slide your clips into your pocket if you sense an encounter coming on, helps to have a shirt that covers the pocket-tops, too, just to avoid attention if that is what you think is coming.
And wearing a knife in a sheath on your belt is "open carry" here. Most of CA actually has pretty good knife laws, it is just in my county, the fixed blade laws get really weird and murky. There's no restriction on length of folding knives, as long as they aren't automatic or balisong, so, I'm just happy about that. Lots of places with "better" laws in one way, having 5 inch restrictions on folders simultaneously. Like Texas, until recently.
But yeah. LA County, fixed blade laws are so murky and contradictory that I just do not bother messing with a fixed blade in public at all. I'll be more likely to slip my Espada XL in my pocket than a Mora Eldris, which is crazy.
Although not a California native, I have lived in California 47 years.
The people running this state now are insane. Obsessed with making law abiding citizens criminals, while releasing real criminals back onto the street.
I like the weather. I'm 70, if I was younger, I'd move.
It can certainly feel that way sometimes. A lot of the stuff that I prepare for in terms of some of the violent people out there today, is related to the preservation of THEIR life, the attacker's, wherever possible.
