- Mar 22, 2014
Did anyone manage to get any of the thicker Vanax from Chuck?
Nice, you hit that with the standard 1975f for 30min with the 390f temper to 60rc?I did a few samples. They’re awaiting grinding.
Nice, what was the RC?I did 1975f and 2000f, cryo, and 400f tempers.
I'm really excited to see where it stacks up on the chart with the other steels.That was before my tester was fixed.
I'm predicting it's the toughest of the PM Stainless steels next just under Nitrobe 77
I sent a good sized piece of .100" to Larrin and he has written some KILLER Patreon Member articles about the steel and heat treatment.
I have been very much enjoying the steel for it's high balance of properties.
I'm going to do some M2 and M4 samples. I was wondering if if it would be worth trying a prequench on one or 2 samples. Is there anything that would be interesting to try? I think I'm doing the samples over 2100. I was also thinking about a high temp sample to see if things really fall off. You can text me at 360.305.6225 if you like.I have some S90V and D2. Also CPM-D2.
You got any ideas about what might even be effective for these? I wanted to try it at a desirable hardness since that's where most will use it.I did 1975 and 2050 on M2 and M4. I also did the first M2 sample at 2100f. I did high and low temper for each condition. M2 is the only steel so far to not have better toughness with low temper. I’m not sure about pre quench.
I’m fine with doing more prequench studies. I already did an article on prequench, not much is known about it. https://knifesteelnerds.com/2018/03/07/austenitizing-part-3-multi-step-austenitizing/
Will they at least give him an epidural?My son, the father, is simultaneously trying to pass a 3mm kidney stone through a significantly smaller tube!
I am currently in possession of a nicely stuffed box of charpy samples from Warren the heat treating machine. Looking forward to getting them ground fro testing!
The issue is this:
My lovely daughter in law is with child and 3cm dilated with my first grandson and only grandchild. My son, the father, is simultaneously trying to pass a 3mm kidney stone through a significantly smaller tube! I May be distracted for a bit, but I'll get them done ASAP! All well wishes and kind thoughts appreciated.
