It's starting to get better after a month or so of use. Still won't fall down but I think it will in time. It atleast goes down easier so I think i just got one the needed alot of use to break in. Those afe some beautiful colors on the ones you both posted! I havent seen either of those variations!!
Lowering the lock bar tension goes a long way toward reducing a sticky lock... I'm just saying
I received my Slim Midi about a week after yours. Mine is smooth, but far from beingdrop free. The lock stick is getting better and my thumb is starting to callus up (which helps). I’ve seen videos online where the blade seems to be more free, but they weren’t the stonewash finish of mine. Since it is textured, I would imagine it takes a while to wear in.
The stonewashed finish should not be on the pivot area of the blade. Should be very smooth. How did you make out with your knife?
Disassemble, note where the lockbar is bent, then bend it back the other way until it actually moves slightlyI know this is an old thread, but with my Slim Midi, the lock bar tension is the issue, not lock stick. How is the lock bar tension lowered?
I’m also wondering if Weasipoint was able to get theirs broken in.
D
Thanks! I definitely won’t be taking it apart, but wouldn’t bending the lock bar even slightly cause an earlier lockup?
I got a Medford Praetorian T barely used that seemed especially stiff to open. Tried some lube on the pivot but that didn't help much. Put lube on the tang but that was a mistake as it now had a bad case of lock stick (may have happened after loosening the pivot screw also). Tried loosening the pivot screw but then the blade was going off center so I put the screw back to the same position it was in and that recentered the blade. Tried sharpie trick and then graphite but that did very little but it still had such bad lock stick I found I had to use a piece of wood to get it unstuck (and I've got very strong fingers and hands).D
