Actually, there is one way you could do it as long as you aren't in a real hurry and you only want to make one or two. If you hunt around you can find power hacksaw blades that are made of all hard M2 high speed steel. They are big enough to make a good size knife from, and they are at somewhere between 62-65 in hardness. They are slow to grind because they are so hard, but because they are HSS you can get them pretty hot without worrying about loosing temper.
I have a Loveless copy drop point that I ground from a power hacksaw blade that is my hunting knife---edge retention on a blade that hard is amazing!
The other option is to buy annealed 1095 from a knife supplier, grind to shape, then heat with charcoal to orange and quench in water or used motor oil. I've done both. Both made good knives, but I think the hacksaw blade is a better option if you just want to make one knife.
Remember, it needs to be all hard HSS, not bimetal. Bimetal blades just have the hardened stuff on the edge---but you could make a sheepsfoot blade with one.
