I dont have better details of your motor. Take this with a caution.
It appears you have a dual voltage capacitor start motor with centrifugal cut out.
That tan terminal thingy is a series to parallel hi-low voltage switch. Presently its in parallel (low voltage) position
Typically this motor wires will have numbers 1,2,3,4,5,8. (6&7 dont exist).
Reversing this type motor, wires 5 & 8 are swapped.
A couple odd things.
Its non-numbered green wires, a fair bet they are numbers 5&8. During installation, one should always check rotation before connecting to the machine. So if initially running backward, one would simply swap 5 & 8. So no real problem there.
But you mention its wires are numbered left to right "1234". Thats odd regards to how the hi-low switch should work.
Are you sure the numbers are not actually 1,3,2,4 ?
Btw,
Here is typical diagram of type of motor I think you have.
http://i.imgur.com/rDnLKCv.png
Btw,
