- Aug 15, 2020
When looking at these instructions I just realized it looks like you’re supposed to use the diamond rods at the 30° angle and then switch to the 40° angle for the other stones but I’m trying to figure out if I am interpreting this correctly
also can I use the instructions for a Hawkville blade or do I need to use the edges instead of the flats of the sharpmaker stones
-cut the edge off by slicing into the medium stone as if you were trying to saw it in half, 2-3 passes
-this should leave the edge reflecting light
-sharpen on the diamond rods at 15, use light force and alternate sides
-stop when the edge is no longer reflecting light
-it should easy slice newsprint now
-switch to 20 dps
-use the flats of the medium rods
-do no more than five passes per side on the flats, very light
-it now will push cut newsprint and shave very easily
-use the flats of the fine rods
-do no more than five passes per side on the flats, exceptionally light
-it now will do silly things like catch hair above the skin
-switch to 20 dps
