    Price is $300 ea (shipped within CONUS). Now open to the forums as a whole. If you live outside the US, I will contact you after your order for extra shipping charges. If there are customs issues? On you.
    User Name
    Serial number request
Can you Etch Aluminum?
I'm wanting to etch my name onto a small aluminum so I can embed it into a folder's handle. Any ideas?
Thanks -chris
Chris, Yes you can. Try a piece first to get the rate speed so you dont go too deep. I ruined my entire etchant by leaving aluminum in overnight. It all turned a milk color and the aluminum was a rounded blob.
Aluminum is easy to etch. Either get muriatic (hydrochloric) acid at a pool supply store or get sodium hydroxide (lye). These are used for chemical milling of aluminum. I have removed up to a 1/16 of an inch of material that way. You need to test your masking material since these will remove a lot of maskants.
I saw this trick for etching brass and thought I would try it with aluminum. It looks like it works pretty well....
You can etch brass with feric-chloride(sp?) from Radio Shack, and you can use a black marker for your resist. You just cover the area to etch with the marker, scribe in you name or whatever, then apply your feric-chloride.
It seems to work best on aluminum after about 2.5 minutes. Then I wipe the excess feric-chloride up with some tissue, dip the aluminum in a little baking-soda water to stop the etch, and clean the marker ink off with a little alcohol.
Well, I hope this helps someone else. Thanks -chris
