Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Your way would certainly work, but I think mine would be easier, especially for a novice. If you stone the flats evenly, you won't change the taper. Admittedly, my method would be better for touch-ups; if the blade is seriously dull, you'd have to sharpen as you describe.frugalweaver said:To sharpen the leatherman saw blade you will need a small swiss jewelers file.
Like the ones here http://wire-sculpture.com/items/G14_8.php
It is best to clamp the saw in a vice so you can work easily and use both hands if needed. File each tooth the same angle and depth. Do not touch the sides of the blade. The taper must stay as it was set at the factory.
Gryffin said:Your way would certainly work, but I think mine would be easier, especially for a novice. If you stone the flats evenly, you won't change the taper. Admittedly, my method would be better for touch-ups; if the blade is seriously dull, you'd have to sharpen as you describe.
Erm... so was I.Bill DeShivs said:I think we are talking about a saw with real teeth, not a scalloped edge.
