- Mar 8, 2008
Again, this is just a hypothesis, but I believe that if a bonded abrasive of anything below "hard" bond, like a medium-soft water stone, was used for the primary shaping work then you'll be more prone to tearout when moving to a sintered ceramic. The thing is that carbides in steel are sort of like rocks in plaster. If the plaster is abraded down against pavement, you end up with the rocks being the only thing that even makes contact. But if the surface is soft enough to wear micro-grooves in it that enable the spaces between the carbides to be abraded then you have the situation where poorly supported carbide "peninsulas" can form. When subjected to the high lateral pressure that sintered ceramics can easily proved, you'd be likely to either tear them right off or roll them over. However, on a hard Norton India, for instance, before moving to the sintered ceramic, you'd be much less likely to encounter that phenomenon, and would instead just be glazing the India stone a bunch rather than causing the carbides to stick way out. Could be wrong, but that's what I'd guess would happen.
