You have to be very careful not to let the carbide burrs chatter, as the cutting edges will chip off if that happens. That being said, they do work very, very well when you hold them steady.
Basically, it takes a very steady, strong grip on the tool, and you have to feed them into the cut exactly the way you would feed an end mill. If you apply pressure at an angle to the edge you are cutting on the work piece, they are prone to start bouncing. So, you need to apply a steady hold, and an even, light pressure parallel to the edge of the workpiece you are cutting.
This all makes a lot more sense if you've done any machining with a milling machine.
