- Jan 9, 2011
Carbide Edge - I get a lot of questions about my 72 RC Carbide Edge Titanium knives. I'll explain a bit here... also just ask if you have any questions! I have made well over 350 knives with the Carbide Edge technology and am proud to put my name on every one as I know they will perform!
Use and Edge Retention - the carbide edge has outstanding edge retention and even self sharpens on abrasive materials like cardboard. Carbide works very well on meat, bone, rubber, cloth, rope, etc. The edge will also saw wood, plastics and more. The carbide edge is very aggressive and just plows through most materials.
The edge stability is good and will hold up quite nicely. I like to stay away from aged hardwoods, thick plastics, drilling with the tip and metal as they are harder on the edge. Check my test video for some very hard use... you will see that these can take just about anything including mild batoning. I designed them for lighter use but was very impressed with what one can take.
Sharpening - these are easy to sharpen with most any setup. Build up a burr from the microbeveled side then just strop or hone off. I like somewhere around 400 grit to sharpen but most anything will do. As a note a finer edge will be easier to strop off and will remain toothy because of the carbide. The edge can get extremely sharp and will shave hair... but you will also get excellent results with a rougher edge than most. I only like to touch my edges up and let the carbide sharpen itself with use.
The Carbide Edge will never flake or wear off. I will apply carbide free of charge to your DFK if it is ever needed. But you won't... The edge is literally part of the knife.
Also - Ti/Carbide is virtually maintenance free, will never rust and a Backpacker with sheath only weighs 1 ounce!
I hope this helps you out and as mentioned please let me know here of you have any questions!
