Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I find there are many very subjective terms that dont matter much, including "cutting speed" that don't tell you squat, unless comparing to other stones.Actual grit, for the most part, doesn't much matter in a practical descriptive sense unless you're comparing it to other stones of otherwise equal overall composition. There are so many other variables involved that it's really more about the results produced compared to other stones in your lineup.![]()
Usually that's more of an issue of porosity. That CAN be the result of the abrasive size, but that's more of like a secondary influencing factor. The grit/bond ratio (which does get impacted by grain size to a degree, but not 100%) and the press rate used in the molding process will have a larger impact. Highly porous stones likely have a low grit/bond ratio and low pressure in molding, which will also make them a softer bond, which increases cutting speed, but also the wear rate.Those Norton Economy stones, i.e. the ACE Hardware stone is a more coarse grit than my JUM-3. A telling sign is I have to use vasoline & oil
to keep the stone lubricated and how fast they cut. So, they are different grit. I'd say the coarse side is closer to 80-90 grit and the fine side is more like a medium, 200 grit. DM
