1AbominAble1
- Jul 26, 2010
With freakishly freezing temps engulfing some parts of the country, I’ve been wondering and musing about some gun related questions which I’ll put to the experts in here:
Suppose that your region gets hit with a really nasty polar vortex when temps drop to really really ungodly cold numbers like minus 40! If so, are then the fancy semi-auto handguns and AR types unreliable? Isn’t it a good idea to own a wheel gun and a bolt action rifle or two under such scenarios? I do know that the more moving parts which need more lubrications run the chance of getting gunked up. Bows and arrows plus atlatls don’t sound that bad then in addition to our CPKs!
it really depends on your firearm and also what you use to maintain it.
I have hunted with an M1A SOCOM 16 in sub zero temps and it has always been flawless, even when caked in snow and ice. I use Tetra gun grease on the op rod on that one and I couldn’t be happier with it.
On the other hand, I used the same grease while cleaning up my go to Glock 23 as well as on the bolt carrier of my PWS Diablo 7 inch barreled AR because it was easier to reach than the slip 2000 and CLP that I normally use. It was June and it seemed fine, fast forward to January and it was -12 overnight and an even zero degrees while we were shooting. Top that off with me leaving the guns locked up in the truck bed overnight because the cabin was full of kids and the guns had a seriou cold soak. It was the only time, in any condition, clean or filthy, that either gun had jammed. They both jammed up due to the grease hardening.
lesson learned, I pay more attention to which products get used on which guns and what weather I’ll be using them in.
Other than that specific incident I’ve never had an issue with a semi automatic rifle or handgun being unreliable due to the cold.
Since you have that new M1A you should be all set
