case blade dot numbers
It's the confusing-as-hell Case dating system. It tells you when your knife was made. From wrcase.com:
"In 1970, Case added ten dots beneath the “U.S.A” on all knife tangs. Each year a dot was removed. In 1980, the same dating system was used. The differences are the “lightning” form of the “s” in “Case” and “USA,” as well as the placement of the dots above the “USA.” From 1990 to mid-1993, the actual date was stamped on the tang. The dot system was used again from mid-1993 through 1999. In 2000, Case introduced a new tang date stamp: five Xs and five dots. From 2001 through 2005, one dot is removed each year. From 2006 through 2009, an X is removed each year."
So if your knife has the lightning-bolt "S" in the words "Case" and "USA", then take the number of dots (say, 4), and subtract it from ten (getting 6, in this case), then add it to 1980 (in this case,m the knife would've been made in 1986).
If it _doesn't_ have the lightning-bolt "S"'s, then I have no idea how to distinguish the 1970's knives from the 1990's ones.
Anybody else know? And, while we're at it, did they start in '93 with ten dots, or seven?
Damed confusing date systems. At least with Buck, you can just look at a chart ;)
blackdoodle said:
What does the number of dots on case knife blades mean?
From thed W.R. Case website.....
What is the Case Dating System?
The Case Dating System is a method for identifying the year a knife was manufactured. The dating symbols are found on the tang stamps at the base of the blade.
heres a copy of text :) right from the Case web sight.
"The Case Dating System is a method for identifying the year a knife was manufactured. The dating symbols are found on the tang stamps at the base of the blade.
I hope this helps
