- Jan 14, 2015
A quick search didn't turn up any results, so i though i might ask in a new thread, if this has already been done, please point me in the right direction.
when searching the web casing is about as elusive/unconclusive as slickening your leather (another thing i am wondering about
the methods and the reason vary widely.
from just soaking it and letting it dry, to leaving it in the fridge while soaked for several hours. or as our very own horsewright does, just a quick dip in a pro carv solution (i'm really going to do a list of stuff i haven't been able to find over here in germany
why do you case the leather? and do you case every piece you work with?
is soaking the leather for wetforming the same as casing?
or is it a preparation for tooling?
or used on every piece to add some stiffness to the leather to add stability?
kinda confused right now.
also do you slicken before or after casing and on which side of the leather? do you use much pressure?
the reason i am asking is that up to now i always used the leather "as it was" (wiped down, but not really wet) unless i needed it to be wetformed (in which case i soaked it under warm running water), or tooled (brushed some water on top of the leather).
now on my current project i noticed once again the obvious difference between soaked (and dired leather) and non soaked leather. though both feel smooth to the touch once more after applying wax, the wetformed part is obviously much stiffer. so from my point of view, if you case leather every piece would gain this stiffness unless you counteract it with eg neatsfoot oil.
sooo, what's it gonna be?
