- Dec 25, 2004
I'll be building a top loading raku and porcelain propane kiln for my and mom's ceramic projects. I'll be using castable refractory cement with high alumina. I've got a usage manual from the refractory company, the correct procedure is after drying the cement about 48 hours, the first drying and firing waaaay too long. Guide says I have to go up 150 C in 6-8 hours and keep at that temp about 12 hours, then in 12 hours I have to go up to 550C and hold there about 1 hour for every 1" thickness. Then to the working temp I'll be heating 100C per hour and hold it about an hour also.
This procedure is inapplicable for me. It needs about 2 or 3 days of continuous firing, that means 2 sleepless nights, tonnes of propane, this is not possible at all
.. What if I don't follow this procedure, I didn't use castable refractory before but I read many people just wait it to be dried then fires it up that's all. The company manual says if you dont follow the procedure the resulting insulation will face leaks because of cracks and says we cannot be held of responsible of mis-drying blah-blah...
So do I simply ignore what do they say???
