Cayanne Pepper?
mmmotorcycle
Captain Slow
I have read in places that if it is fine ground it can be used to clot wounds. Is this true? and Where could I get a supply of some?
ive read that too.i dont know if it works but it's available at the grocery store in the spices aisle
That sounds like the most painful thing you could possibly rub into a wound. Cayenne pepper contains Oleoresin Capsicum, the active ingredient in pepper spray- a severe inflammatory agent. It might cause a cut area to swell up and restrict bleeding, but it might not. It certainly WILL make it hurt a lot more. This sounds like something a frat boy would tell another frat boy as a prank.
FB#1: "Hey I just cut myself!"
FB#2: "Rub some cayenne pepper into it, man, I hear it really helps"
FB#1: "Okay, thanks! (rub rub ru...) OWWWWWWWW! You bastard!"
FB#2: "Huh huh huh. You're stupid"
I've heard that too. Volunteers? (All step back except for...). Mmmotorcycle we would all like to thank you for voluteering for this test. Please hold out your arm. Hey! Where did he run off too?
LOL!:D . Seriously tho... I recall some one on the forum getting a bad knife wound and saying they poured the pepper into the wound and used super glue to seal it shut. Apparently it leaves a cleaner scar than stitiches do.
I will have some of the pepper close at hand the next time I chop a finger or stab myself when I'm a little more tired than normal....:yawn: . Who knows? I might go into shock because of the pain.
mmm please try to post your responce before the ambulance gets there. Enquiring minds want to know. :)
my fiancee is a diabetic...
maybe next time she pricks her finger to test her blood sugar i sneak a little pinch on there
:D
I've heard it, don't want to try it. As for superglue I imagine it's like covering cuts with duct tape, closes it but really not a good choice health wise if you have another option.
The OC issue aside, I strongly suggest not contaminating an open wound with any substance. With out having tried the new Quik-Clot type anti-coagulant I will stick to the traditional treatment. However, using Super Glue to seal the edges of the wound closed is good. If anyone can point me to text on natural topical anti-coagulants (such as bee comb) I would be happy to educate myself further and maybe change my mind.
using pepper or glue or duct tape on an open wound sounds like the recipie for a grand infection...Take a first aid class, if you haven't already and practice the dressings..Learning how to do a really good one is an art unto itself, and you can get stock up on some first aid supplies as any drug store.
wow next time some one gets a cut im going to suggest that they salt the wound & apply some cayenne..... then season with mrs. dash to taste :D :thumbup:
on a serious note, ive also read that it works like quick clot & it doesnt burn (as much or at all?) as it seems it would :confused:
ummmmm i assume this only applies in an emergency situation where only cayenne pepper is accessible and you have a bleeder?
I dont know about cayenne pepper ON a wound,but taken INTERNALLY it is a blood thinner.
Also, Crazy Glue was originally developed as a field replacement for sutures by the Army and works quite well in this capacity.
CAYENNE PEPPER - EMERGENCY USES
Compiled And Edited By Tom Harrelson
THERAPEUTIC ACTION
CAYENNE is a POWERFUL and PURE Stimulant, having NO Narcotic Effect, increasing the POWER of the Pulse and carrying the Blood to ALL parts of the Body, plus EQUALIZING and RESTORING the BALANCE of Circulation throughout the Body! Cayenne is a Hemostat, ARRESTING the flow of Blood from a Cut or Wound in SECONDS and a Cardiac Tonic, HELPING to REBUILD the Heart. It is an Antiseptic, KILLING Pathogens and a Counter-Irritant, helping to RELIEVE Pain. And Cayenne is a Stomachic, HELPING to DIGEST Foods and a Carminative, HELPING to EXPEL Gas. CAYENNE PEPPER IS DR. SCHULZE'S NO. 1 EMERGENCY HERB!
FORMULA
The BEST Cayenne Pepper Tincture is made by the following Dr. Schulze Method:
1. Start to make this and ANY Tincture, if possible, on a NEW Moon.
2. Take a Quart Canning Jar and fill it 1/4 FULL with DRIED Cayenne Peppers, getting the HOTTEST ones (i.e. - Habanero, African Bird, Serrano, Jalapeno - 90,000+ Heat Units), that you can obtain.
3. Add enough 50% Grain Alcohol (100 Proof Vodka) to the Cayenne Peppers (powdered, using a Blender or Grinder) to just COVER them.
4. Use enough FRESH Cayenne Peppers, that you can blend with 50% Grain Alcohol (100 Proof Vodka) to turn the Mixture into an Apple Sauce-Like Consistency.
5. Add this Mixture to the 1st Mixture, filling up the Canning Jar 3/4 FULL.
6. Fill up the rest of the Canning Jar with MORE 50% Grain Alcohol (100 Proof Vodka).
7. Shake it as MANY times as possible, during the Day.
8. Let this Mixture sit, until the following FULL Moon (15-16 Days), but OPTIMALLY until the following NEW Moon (28-29 Days)!
9. Strain this Mixture through an UNBLEACHED Coffee Filter.
10. Bottle the RESULTING Tincture.
NOTE: Part EQUALS Volume, NOT Weight in this Tincture Method. Modify this procedure by using DRIED Herbs ONLY, if FRESH Herbs are NOT AVAILABLE, and when making other Herbal Tinctures also. Also if you want to make a SUPER-POTENT Tincture (i.e. - Cayenne Pepper & Lobelia Seed Pod - see below), then allow the Mixture to sit for a FULL 3 Months!
APPLICATIONS & DOSAGES
NOTE: In the following Steps of this Section, "Dropperfuls" or "tsp." are referring to Cayenne Pepper Tincture, unless otherwise noted. SUBSTITUTE Cayenne Pepper Powder (250,000 Heat Units or above - Habanero, African Bird, Serrano, Jalapeno), if Cayenne Pepper Tincture is NOT AVAILABLE. 1 HEAPING Tablespoon added to an 8 oz. Glass of PURE Water is EQUAL to 5 Dropperfuls of Tincture. 1 Dropperful EQUALS 30 Drops.
If you're working with an UNCONSCIOUS Person, you must be CAREFUL, when putting the Dropperfuls into the Mouth, so that you do NOT CHOKE or DROWN this Person, but then even if he/she GAGS a little, you are SAVING his/her LIFE!! The above recommendations for a Heart Attack came from Dr. Richard Schulze, M.H., N.D., who saw MANY MIRACLES with his Methods!
BLEEDING
If a Person has SERIOUS EXTERNAL BLEEDING (Cuts, Wounds, & Childbirth Hemorrhage/Tear), you must:
1. LIBERALLY FLUSH the AFFECTED Area with 10 - 20 Dropperfuls of Cayenne Pepper Tincture IMMEDIATELY or PACK the Area with Cayenne Pepper Powder, if the Cayenne Pepper Tincture is NOT AVAILABLE!
2. Give 1 - 3 Dropperfuls of Cayenne Pepper Tincture ORALLY also.
3. If Echinacea Plus Tincture is AVAILABLE, FLUSH the AFFECTED Area with 10 - 20 Dropperfuls.
4. Apply Pressure to a Cut/Wound/Tear or use Arterial Pressure.
5. Tape the Cut/Wound/Tear together.
6. Apply Aloe Vera Gel to the AFFECTED Area on the following day.
7. If Pain is involved, then give 5 - 60 Drops 3 - 4 times daily of an EQUAL amount of Valerian Root Tincture to the Lobelia Seed Pod Tincture.
8. If OPEN SORES or WOUNDS are NOT HEALING, apply Slippery Elm Gruel over the AFFECTED Area each day, until desired RESULTS are achieved.
If a Person has SERIOUS INTERNAL BLEEDING (Ulcers, Hemorraghes), you must:
1. Give 1/8 tsp. of Cayenne Pepper Tincture - 8 times per day.
2. And then WORK your way up to taking 1 tsp. of Cayenne Pepper Tincture - 3 times per day.
If a Woman has a HEAVY MENSTRUAL FLOW, you must:
1. Give/take 1 - 3 Dropperfuls of Cayenne Pepper Tincture ORALLY.
2. If Pain is involved, then give 5 - 60 Drops 3 - 4 times daily of an EQUAL amount of Valerian Root Tincture to the Lobelia Seed Pod Tincture.
BREATHING PROBLEMS
If a Person has STOPPED BREATHING and is CONSCIOUS, you must:
1. IMMEDIATELY Check Airway and Pulse!
2. Start Mouth-to-Mouth Resuscitation.
3. Give 5 - 10 Dropperfuls of Cayenne Pepper Tincture DIRECTLY into the Mouth, HELPING the Person to REVIVE!
4. Give 2 - 10 Dropperfuls of Lobelia Seed Pod Tincture or MORE, HELPING the Person to BREATHE EASIER, OPEN UP their AIRWAY and RELAX!.
5. REPEAT Dosages of BOTH Tinctures, ALTERNATING each EVERY 5 minutes.
If a Person has STOPPED BREATHING and is NOT CONSCIOUS, you must:
2. Start Mouth-to-Mouth Resuscitation!
3. Give 1 - 2 Dropperfuls of Cayenne Pepper Tincture DIRECTLY into the Mouth, HELPING the Person to REVIVE!
4. Give 1 - 2 Dropperfuls of Lobelia Seed Pod Tincture or MORE, HELPING the Person to BREATHE EASIER, OPEN UP their AIRWAY and RELAX!.
If a Person has SMOKE INHALATION and is NOT or BARELY CONSCIOUS, you must:
1. IMMEDIATELY Start First-Aid Treatment for Smoke Inhalation!
2. Give 1 - 2 Dropperfuls of Cayenne Pepper Tincture DIRECTLY into the Mouth, HELPING the Person to REVIVE!
3. Give 1 - 2 Dropperfuls of Lobelia Seed Pod Tincture or MORE, HELPING the Person to BREATHE EASIER, OPEN UP their AIRWAY and RELAX!.
4. REPEAT Dosages of BOTH Tinctures, ALTERNATING each EVERY 5 minutes.
CIRCULATION PROBLEMS
If a Person has a HEART ATTACK (Angina Pectoris) and is CONSCIOUS, you must:
1. IMMEDIATELY give 5 - 10 Dropperfuls of Cayenne Pepper Tincture DIRECTLY into the Mouth!
2. Sit/lay the Person down and LOOSEN Clothing.
3. REPEAT the Cayenne Pepper Tincture Dosage in 5 minutes and, if you have it, 4. Give an EQUAL amount of Dr. Schulze's Heart Formula Tincture (1 Part - Cayenne & 3 Parts - Hawthorn Berry).
6. Continue this Treatment, until the desired RESULTS are achieved.
If a Person has a HEART ATTACK (Angina Pectoris) and is NOT CONSCIOUS, you must:
1. IMMEDIATELY give 1 - 3 Dropperfuls of Cayenne Pepper Tincture DIRECTLY into the Mouth!
2. Check Pulse and Breathing.
3. IMMEDIATELY START C.P.R.!
4. REPEAT Dosage in 5 minutes and, if you have it,
5. Give an EQUAL amount of Dr. Schulze's Heart Formula Tincture (1 Part - Cayenne & 3 Parts - Hawthorn Berry).
6. REPEAT Dosages of BOTH Tinctures, ALTERNATING each EVERY 5 minutes.
7. Continue this Treatment, until the desired RESULTS are achieved.
If a Person has a STROKE and is CONSCIOUS, you must:
1. IMMEDIATELY give 5 - 10 Dropperfuls DIRECTLY into the Mouth!
If a Person has a STROKE and is NOT CONSCIOUS, you must:
1. IMMEDIATELY give 1 - 3 Dropperfuls DIRECTLY into the Mouth!
3. Start C.P.R.!
5. Give an EQUAL amount of Dr. Schulze's Brain Formula Tincture.
If a Person has General Circulation &/or Blood Pressure Problems, they should:
1. Change the Tincture Formula above to 2 parts - Garlic, 1 part - Ginger Root, and 1 part - Cayenne Pepper.
2. Take 1/8 tsp. - 4 times per Day.
3. Work their way up to taking 1 tsp. - twice per day.
If a Person has Heart Problems, they should:
1. Change the Tincture Formula above to 3 parts - Hawthorn Berry and 1 part - Cayenne Pepper.
DROWNING
If a Person has DROWNED, you must:
1. IMMEDIATELY Start First-Aid Treatment for Drowning!
INTERNAL PAIN
If a Person has a MIGRAINE Headache, you must:
1. Give 5 - 10 Dropperfuls of Cayenne Pepper Tincture at ONCE!
2. But if Step 1 does NOT WORK after 1/2 hr., then mix an EQUAL amount of Valerian Root Tincture and Lobelia Seed Pod Tincture together.
3. Give 5 - 10 Dropperfuls of this Tincture Blend at ONCE!
4. Give 3 - 4 Glasses of PURE Water with a pinch of Sea Salt in a SHORT period of time.
5. Continue this Treatment, until the desired RESULTS are achieved.
CAYENNE PEPPER OIL - THERAPEUTIC ACTION
CAYENNE, acting as a Counter-Irritant, plus the Oil as an Emollient, work DEEP into Tissue to RELIEVE Pain, Sweliing and Inflammation. It can also be used for Stiffness in Joints, Tendons, Ligaments and Muscles for Health Problems, including Arthritis, Bursitis, Lumbago, or ANY Muscle or Bone Pain.
FORMULA
Cayenne Pepper Oil is made by the following Method:
1. Start to make this Oil, if possible, on a NEW Moon.
2. Place 5 tbs. of Cayenne Pepper (HOTTEST - Habanero, African Bird, Serrano, Jalapeno) Powder into 20 oz. of RAW ORGANIC Jojoba Oil, Almond Oil or Olive Oil into a Glass Jar with a TIGHT lid and SHAKE EVERY Day.
3. PRESS and STRAIN OFF the Oil Mixture through Cheesecloth or Cotton Muslin Cloth on the following FULL Moon.
4. BOTTLE it.
If a Person has HEMORRHOIDS or INJURED Tissues, where the Skin is NOT broken, you must:
1. Take a HOT Bath or Shower.
2. Thoroughly RUB 1 or MORE Dropperfuls into the AFFECTED Area of the Skin for 15 minutes.
3. Alternate VERY HOT, then VERY COLD Water over the AFFECTED Area for 1 minute each for 7 - 10 times.
4. If Pain PERSISTS, give 5 - 60 Drops 3 - 4 times daily of an EQUAL amount of Valerian Root Tincture to the Lobelia Seed Pod Tincture.
NOTE: This Oil can be EXTREMELY HOT on Hemorrhoids, so start with a SMALL amount and work your way up to MORE! Do NOT apply this Oil on Broken Skin! SUBSTITUTE a HOT Water Bottle and an ICE Pack or Cubes, if VERY HOT and VERY COLD Water is NOT AVAILABLE!
Remedy #4: Cayenne Pepper
3 YEA
Jane from Poulsbo writes, "Applying powdered cayenne to a wound stops the bleeding within minutes! I've read that you can also take it to treat internal bleeding. I think the recipe is 1/4 teaspoon in a glass of tomato juice."
9/3/2006: Douglas from Monticello, FL writes, "Cayenne pepper stops bleeding and heals the wound, even one that the bone could be seen in the heel of the hand. The scar is almost nil."
12/11/2006: Elizabeth from Gulfport, Mississippi writes, "I used cayenne pepper on a fresh cut on my arm. The cayenne pepper stopped the bleeding. The cayenne pepper will only sting for a second."
Superglue on a cut is not a bad thing and won't give you an infection unless you've already introduced bacteria into the wound. In fact, super glue was originally developed as a replacement for butterfly bandages and sutures on smaller lacerations. Several surgical adhesives are in use that have nearly the same chemical make-up as off-the-shelf Krazy Glue.
Cayanne pepper? Beats the crap out of me. Then again, my stepfather told me that salt would stop the bleeding of a scrape when I was a little kid....
No comment about your ( ! ) stepfather. :D
For the poster that asked, Ceyenne pepper can be gotten at any grocer that sells spices. I use it on most of my food. Not being able to drink alcohol, I won't be making up any tinctures, but I do carry both ceyenne and honey in my vehicle and gear. Both work very well in the food and med sections.
Being we all know now that it is a cure all, here you go, here is my source. I hope you notice that I put the 160,000 Scoville units pepper in the link, I want to see if I can hear you scream from all the way to where I live at.:D
It actually is very good pepper at a great price.
Enjoy.:D
http://www.spicebarn.com/cayenne_red_pepper_160k.htm
I actually use the 60 K pepper for my jerky but what the heck, 160K will probably stop the bleeding twice as fast.
I also heard that if you use tincture of Oakmallet it helps shut you up after using the tincture of cayanne. d:)
Pitdog thanks for the info but I put my foil hat on and stopped reading when it said I should start taking the tincture on a new moon. :p
