That is one awesome 710. Best I’ve ever seen.Un-numbered -141 blade in my (walrus) ivory scales.
Aesthetically, it looks fine; however, with a multicolor scale like that black/blue, it accentuates the screws and changes the lines by curving around them (if that’s what you’re aiming for). If not, perhaps that program is a better fit for solid scale material? More importantly, how does it feel when sliding the fingers over the AXIS lock to disengage? Do you notice the .1” bump? I imagine you’d need to carry and use it for a short period of time to see if that bugs the user or not Ryan. If it does, could a gradual .540 to .645 near the pivot work to avoid that lip? I suppose it would defeat the purpose. Just a thought.Looking for some opinions on this.
Visually I’m good with it. Looks like it Could provide more feel to the knife overall. Could the rings be added to the other heads to make it more cohesive maybe? I like the look of it different options are nice to see to make it more custom.
I’m glad to see more programming from you! (As I secretly hope to see 707 scales lol)
I would like to see it, I think for me it would be more aesthetically pleasing to see the rings through out the knife, but I could also be wrong. I like the bump out better than when people add the extra stepped ring around the screws. I’m curious if the mini barrage has room to slim down? One of the only reasons I got rid of it was it was chunky. Though I never got to try yours either with the ball mill chamfer which I’m sure helped.I was actually thinking about adding the rings to the other screws. Still considering it. My only hesitation there is right now it feels pretty much like the knife normally does, it bumps out around the axis, pivot and liner screw, but it always kind of does on the stock knife because all those items hang out slightly from the scale anyway. So you're sort of used to feeling stuff there. The backspacer screws aren't something that are raised on the stock scales though. I might just have to make one like that and see how it feels.
I also want to rework the chamfer that goes along the profile of the knife so it doesn't cut into the ring on the back side of the axis lock, which is a bit hard to see in the picture.
We'll see, probably revise my program a bit and make another one sunday.
I see I figured the coil was part of the issue I never thought about the exposed pivot nor did I realize the full size was hidden on both sides...There's no making the mini barrage thinner with out getting really weird. The side with the exposed pivot really sets the thickness. To go any thinner you'd be exposing the whole drum that houses the assist spring, and then having that pivot stick out on top of that. Not sure why the assist assembly is actually slimmer on the full size but it is. I don't have the measurements handy but maybe they went with a larger diameter spring on the full size which allowed them to go thinner gauge or fewer coils on the spring making the whole thing lower. I know the pivot head on the full size is also much thinner. I feel like if they would have went with a pivot that thin on the mini, they could have at least covered it over with the scale like they do on the large.
Working on it. I have one in hand now, going to be the next thing I program after I finish my thin griptilian program. Should have it done sometime in January if not before.I can't wait to see some Bugouts
Ok I lied before... NOW I'm doing working on the slim griptilian program. Put some better diagonal tool paths in. Looks great and leaves a nice texture. Not sure how well they'll show up in the pictures though, it's pretty fine.
Also other stuff I've made over the last week.
