The long and short of it is we don't need CBN for knifemaking.
An 8"X1.5" wheel cost $200 - That is about the minimum size that would work for knifemaking. I haven't seen any CBN wheels larger than 8".
All you can do with one is make hollow grinds - and the 8" hollow will work on small blades. A 1/8" blade will make a .6" hollow grind.
They are only a very thin bonded layer of CBN on steel - This can easily be damaged by misuse.
There is no repair for a damaged wheel - One slip and $200 is out the window.
They are only really useful for sharpening high hardness tooling, tungsten, or carbide - this is what they are made for.
(I won't say they don't exist, but I have never seen a large flat disc that was completely covered in CBN. 2-3" is all I have run across. Larger discs are either rim coated for slitting, or have a 1/2" raised lip that surface grinds.)
If you have your heart set on using a very hard abrasive, try diamond belts, wheels, discs, and polishes. I have not seen an off the shelf 2X72 diamond belt, but they can be made up by places like Eastwind Diamond. A 60 grit 2X72 industrial grade belt probably would cost several hundred bucks a belt. Normally, they are used on expanded rubber drums up to 8" diameter. Use on a belt grinder may greatly shorten the abrasive life because of the flexing.
I have a 6" diamond expandable drum setup that I will likely put in the new shop. It is run wet and used for shaping and polishing stones and glass. On the other side of it is a 100 grit 6X1" diamond wheel. That sucker will re-sharpen even the toughest carbide tooling.
Years ago, I had a 10" diamond flat lap that I donated to the local Gem and Mineral society along with a bunch of other lapidary equipment. The flap lap might have had some knife use, but the lapping discs cost about $50 each. They came in grits from 60 to 3000
