- May 19, 2010
A series of Bladesmith oriented questions concerning the use and application of Cerakote have come up. I hope this is the correct place to address these questions.
What is Cerakote? - Cerakote is a high tech coating for objects such as knives and firearms. It's qualities include extreme abrasion resistance, extreme impact resistance and extreme chemical resistance. Laboratory tests have shown that a properly coated metal piece can withstand over 3000 hours of salt spray without any change to the coating or the metal underneath.
How is it applied? - Cerakote is appied using a small HVLP spray gun, similar to those used for automotive finishes.
What surface prep must I do before sending the blade in for coating? - Cerakote is applied after a fresh sand blast. The blast is performed with 120 grit garnet or Alox. I use garnet. You should have your blade ready to accept this gentle grit blast.
=======added 10/2/10========= Finish your blade so there are no visible surface irregularities. Anything visible before coating will be there after coating.
How thick is the coating? - A properly applied Cerakote coating is approximately 1 mil (0.001") thin.
What colors can I get? - Cerakote comes in 40 colors. Further, these colors can be combined into a variety of camouflage patterns. Patterns may be freehand or utilizing stencils. Stencils lend well to creativity. For instance, we could have skull stencils made. Using a skull stencil we could produce a two color finish that include a black knife with pink skulls. I am being a bit silly but it is illustrative of what can be accomplished.
Does the second or third color add dimension? - Yes. About 1 mil per color.
Is Cerakote a heat cure product? - Yes. The heat profile for blades is 1 hour at 250 Fahrenheit (F) and then air cooled. I do not believe this will effect any heat treat. We apply it to heat treated guns all the time.
What about handle materials? - We commonly apply Cerakote to Glass filled nylon and Carbon fiber gun products. Because the impact and abrasion resistance of the coating relies somewhat on that the substrate, we can utilize a shorter and cooler bake for synthetics. At my factory training we utilized 200F for 20 minutes on synthetics. I checked here and learned that the various Micarta products are safely heated to 250F.
What about wood handles? - We do not apply Cerakote to wood products. I believe this is due to the soft nature of most woods compared to metallic substrates.
Who makes Cerakote? Where can I learn more? NIC Industries is the manufacturer. They have an extensive knowledgebase about this terrific product listed on their website. Please have a look.
I hope this gives us a solid start on getting you the information you need. My goal is to provide bladesmiths another tool in their arsenal. Allowing them a wider product line and ultimately a mutually beneficial relationship. I cannot think of anything else to add. But, I am not a knifemaker. I am certain you will have more questions or concerns. If after you have read this something more comes up, please address it here. I will answer as quickly as I can.
