Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Depends on the type of ceramic and the type of carbide. There are some carbides that are harder than several type of ceramic, like Tungsten or Vanadium carbide, which are both very hard.
There are some types of ceramic that are harder than either of those though from what I know. "ceramic" is more a term describing the method of making something and its structure than an actual specific substance, like how "steel" is a broad concept/category for all of the different formulas as well.
The definitions of ceramics have changed greatly since early days. "carbides" such as tungsten carbides are made with tungsten carbide particles 'glued 'together with cobalt .Depending on type they vary with percentage of cobalt and size of carbides . Ceramics are sometimes "sintered " heated to bond the particles without a secondary 'glue'.
Kyocera's website lists their ceramic blade (zirconium oxide) hardness to be 8.2 mohs. Not sure what that equates to in HRC.
I'm not sure where you got the HRC 72 though. Look at http://www.bladeforums.com/forums/s...based-on-Edge-Retention-cutting-5-8-quot-rope
The highest measured HRC is 65 for ZDP-189. Even Phil Wilson's custom knives are on the ragged edge of HRC 65 range. And he's perhaps the best, most at the extreme with heat treatment in the industry.
Does anyone know a Rockwell value that could be attributed to ceramics?
Absolutely correct!
Ceramic and carbide are very similar in the fact they are both sintered materials, just the base and binder are different, depending on their application or use.
As for hardness, tungsten carbide is measured in the Vickers scale, well beyond the range of the Rockwell C scale. If carbide is around 2,600 Vickers HV, think of it as roughly equivalent to 120Rc on the Rockwell scale. Good stuff.... I'm not positive which would be ultimately "harder", although my guess would be a ceramic - but it would be very brittle.
I got the 72 RC from multiple custom knife makers who use the process of carbidizing, adhearing the carbide (tungsten or titanium) to one side of the edge of a blade. And Rex 121 is the only steel I have seen used to make a knife that goes beyond 70 RC.
It's interesting to see what custom makers can do beyond "normal" production. I guess that's really akin to industrial diamond tipped bits and so forth. In my mind, that doesn't fit into what I would consider a steel blade though as they sound more like a coating. So normal sharpening would more likely pull the carbides off rather than sharpening them?
