I dont know much about ceramic knives. What are your thoughts & how do sharpen them. Everywhere ive read it says you have to send them back to the manufacture for sharpening. I dont believe its rock science to sharpen a knife with a ceramic blade I just have not found out how yet. Everyone of them ive seen in stores dosent feel very sharp to me. Thanks
Suit yourself, but I'll bet my salary against yours that you won't be able to do a good job with typical at-home sharpeners. Also, it doesn't feel sharp because it really isn't. It is harder than any other surface so it cuts by friction. If you were to draw that
dull ceramic across your palm with a little bit of downward force, you will see a lot of red.
You will need diamond sharpeners in order to hone ceramic blades. Zirconia ceramic knives have a hardness on the Mohs scale of 8.5. Diamond is 10 and the hardest steel knives are around 6-6.5 Mohs.
Ceramic knives don't really dull like steel, but will eventually lose its edge due to micro chipping. the good thing is that it can take a long time, like years, for this to happen.
The bad thing is that if you don't know what you're doing, you will probably chip it worse if you try to hand sharpen it. (I put myself in this category and I've owned ceramics since the mid 1990s).
The only good way to sharpen ceramic knives is by machine with diamond abrasive set at the proper angle. You are actually regrinding a new bevel into the ceramic Think of creating a bevel in glass, it needs to be ground, not chipped.
Lastly, ceramic blades are good for certain functions like cutting paper, string and in cutting/garnishing vegetables. Ceramic blades are not very good for cutting meat, fish or for chopping. I have even chipped-up the edges on a ceramic chefs knife after trying to slice hard-crusted bread before.
