I got some reference to this issue in another thread but since it is not related to the previous thread title I decided to start a focused new topic.
I got a few ceramic rods which I bought from Ebay but they are too coarse which is not the best application for a rod. I read on this forums before that it is possible to restore Spyderco ceramic stones after they get blunt. I decided to try to do it to a rod and I scrubbed it with a course SiC grit. The rod got very smooth but it lost abrasive property since the surface got bold.
However, if it's a sintered ceramic rod (like a Spyderco ceramic) then you'll NEED diamond, as the difference of hardness between SiC and aluminum oxide is only very slight.
I tried to scrub the rod for about 10 minutes with a diamond plate but it did absolutely nothing to the stone. I was applying very light pressure since I did not want to damage the plate. Unfortunately I did not see any abrasiveness on a smooth surface of the rod. Do I need to press harder or use some oil?You can still use a flat diamond plate to refresh the round ceramic rod, just scrub it up and down the length of the ceramic rod and slowly rotate the ceramic every several strokes up and down.
