Chap Repair
Horsewright
Had a friend bring me a pair of chaps to repair for him. Thought I'd do a lil WIP on how it went.
There are many kinds of chaps and in fact we often use the term legging as a generic term as there are so many types. I've pretty much over the years made them all: shotguns, AZ bells, charmitas, armitas, chinks, rodeo chaps, bat wings, farrier chaps, show chaps etc. This is a pair of AZ bells that we'll be working on. They are often referred to as "step ins cause that's how ya put em on, you step into them. However, just to confuse things a true pair of armitas are also referred to as step ins but they are a totally different types of leggings. Not to be confusing or anything.
Anyhoo this pair of "bells" were brought to me by my friend Josh. He and his wife run one of the biggest ranches in this area and they were our neighbors on two sides when we had our ranch. Their outfit is about 57 square miles so these leggings have seen some use. Interestingly this type of legging is kinda relatively newcomer to California, I'd say with in the last 10-15 years. Now just about every working cowboy I know around here wears this type of chap and I've made quite a few from scratch. Anyhoo:
Here they are on the workbench. These are roughout one made out of what looks like glovetan leather to me. Our new pocket will be made from some nubuck scrap I had.
I think that there was a weakness in the letter side right there but also that's where a guy's rope would drag some and that can be pretty abrasive. Don't matter much still gonna fix em up.
Here's what needs fixing the pocket has worn through and ripped the leg leather. The first thing I have to do is untie that knot in the pic above and separate the two legs. Josh also asked if I could do two rows of stitching on the new pocket to match the rest of the leggings. For some reason the maker had only done one row of stitching on the pocket but two on everything else. Even on the patch pocket on the other leg below he'd done two rows of stitching.
With the legs separated I'll set this one leg aside as we're not doing anything with this leg. See that lacing on the leg though? That's our next step we have to unlace the leg we're working on. The lacing is what holds the chap leg together.
Unlacing one of these and lacing it back together is kind of a pita and takes longer than anything else. It just takes a while, did I mention its kinda a pita? Our next step is to pick out all the old stitches holding the old pocket in. This type of pocket is known as a welt pocket. It's literally a pocket built into a slit in the leg leather. I didn't know the guy that had made this pair but he'd down some pretty good work. However he didn't punch a hole in each end of this slit, and you really should. You do this fro help prevent the leather from spitting along the slit and here, that's exactly what happened.
Here is the new pocket with the old pocket. I had to make the new pocket wider and a lil bigger so it would cover the old stitching holes.
I also had to widen the slit so I punched the appropriate holes and slit open the slit to the holes.
I fit in the new pocket and glue and sew the top flap down first. Then the important part, so ya don't get bit.
You have to turn the leg over and flip the pocket up and out of the way to sew down the bottom flap. Forget to do this and you will literally sew the pocket closed.
Here I'll trim the threads and then flip the pocket up to sew the bottom flap. Notice that on the pocket itself I stopped sewing about and inch from the slit. This is intentional and makes a stronger welt pocket. You are not straining those stitches every time you put something in the pocket. You sew all the way up and you are straining those stitches. Something learned from experience.
After the bottom flap is done all that is left is to re lace the leg up and then tie the center string knot again.
All done:
Hope ya enjoyed this lil WIP, just something a lil different. Questions and comments always welcome.
All done:
Always a pleasure to follow along...👌Fine job....👍
Very cool, Dave.
I always enjoy your “WIP” threads.
Great work as usual !!
Very cool, Dave.
Good deal! Thanks guys! Just a lilsomthing that most folks don't run into too often.
You are an extraordinary craftsman with a teacher's heart.
Just the other day you helped me to learn the Bleed Knot.
How did I do?
Perfect! See how your last one is not quite laying flat, got a lil twist in it? So it could be that that last slit is a hair and I mean just a hair too short and that's what's causing the twist. What a guy can do besides cutting the slit longer is to lay em flat and tap the knot with a smooth faced hammer. This is less intrusive than re cutting the slit. I'm all about less intrusive. That's really nit picking btw, they look great!
Hi Dave
I don't post here much but I read everything you post. I'm actually working on a bag now that I pIan to post photos of in your ongoing thread. I have learned so much from you and use the skills everyday in my leatherwork, so thank you.
I have a question about leggings, if you don't mind. I have always wondered why leggings are made so short. We all know that when you sit down they ride up but even when a person is standing, it seems the leggings are short, often riding up around the tops of ones boots. Also, I've always thought chaps were to protect the riders legs but when they ride up they often leave much of the leg unprotected. Can you make sense of that for me?
These aren't questions a guy can ask just any old observer so he might as well go to a pro, eh?
Thanks again, Dave.
First thanks for the kind words. Glad to be of help.
Have you read this older thread?
I go over the many different types of leggings in that thread.
To answer your questions though. Some of the shorter styles are made that way to not be so hot in warmer weather. You do get a lot of protection from the ankle up to the upper shin from your boot tops and the stirrup leather of the saddle. Some areas are more open then others too so ya don't need all that protection but leggings can still add warmth and some stickiness to the saddle. Use to call riding without leggings "riding naked".
On the shortness of full length types of leggings AZ, bells, Batwings, shotguns etc you don't want them too long. Ya see that in show chaps but not in the working arena. You are not wanting to get them long enough that they are dragging in the mud etc. But long enough if you are in brushy country to add some more protection.
Low bridge.
Corner office with a view:
This is the customer wearing a pair of Bells there in AZ. Liked em so much he ordered another set:
My son wearing his shotguns in NV for warmth. 8 degrees that morning:
Hope this helps some. If I didn't get the question answered let me know and we'll get er lined out for sure.
Thanks Dave. That all makes sense and I always enjoy your photos.
I hadn't read the thread you referenced but now I will.
Cheers.
Edit: I read that whole thread about leggings. As usual it was hugely enjoyable. Love all the photos.
Cheers.
Ya bet any time
Cheers.
Here's another oldie but Goldie ya might like!
