David Martin
Moderator
- Apr 7, 2008
Ok, I've now had the chance to give this Charnley Forest a test run. I took a Feathers double edge Used blade to it, having 10-11 shaves on it.
The last shave with it was shaving sluggish and I was having to use more pressure. So, I took the blade to it using H20 and a backhoning
stroke. I gave it 40 on each edge then 10, 7, 5 & 5 to remove the burr. Then checked it and didn't think it was quite there so I did it again.
It felt better this time and I then did a full shave on a 2 day beard. No stropping, just off the stone. I used our local goat's milk soap, Udder Delight for a good lather. This gave an exceptionally close, smooth shave. Better than when the blade was New. So, the feed back about this stone is accurate. It is a great stand alone stone for shaving. DM
