- May 19, 2007
If I'm reading that right, Crappy has nothing to do with how strong the detent is, its on a continuum. If your detent is so strong that you have the blade slamming open, shock-loading everything, and sticking the lock, then is probably just as bad as one so soft as to allow the blade to swing open easily.A crappy detent is a detent that does not serve to retain the blade in the handle adequately. A weak detent makes for a soft flipper, while a strong detent makes for a hard snappy flipper.
The detent is only one aspect of the entire knife, and just saying that its only measure of function is if the knife pops open seems limiting to me. The detent could be just fine, but maybe the flipper tab isn't long enough to get enough rotation into the blade, maybe the bearing surfaces inside the pivot provide too much drag, maybe the overall design of the knife does't let the user's finger apply enough force quickly enough. Its not like a rifle trigger where is just a squeeze and break. I mean you could set up a flipper that way, so you are just converting your finger into a spring to assist the opening, or it could be that your finger acts in a more kinetic manner. The point is, just saying good or bad is subjective, and overall not very helpful, because it doesn't actually describe the function of the knife in a way that translates to anyone else.
Would that be a fair assessment?
