mitch,
I am not trying to be argumentative, but you asked if anyone knew about the method. You even said it was done in a vibratory tumbler.
I responded that the use of it I was familiar with would not work as you planned, and would not be useful for knife blades.
You said that you didn't see why it would not work.
Someone else said it would not be a good method.
You responded that you didn't plan on using a tumbler, just wiping off the surface with the chemicals.
This method uses chemicals that are only licensed by REM, and specialized equipment. It takes a lot of money to do this. The results may or may not be of any use to a knifemaker anyway. It is not a wipe-on....wipe off process.
Here is an excerpt from REMs own data:
The REM (R) procedure is not a polishing process but rather a finishing process. The REM procedure involves two steps. The first step, referred to as the "Refinement Process", involves a chemical interaction on the surface of the part. A soft, thin (one micron) film is formed on the surface of the part. The part then interacts with the ceramic media in a special vibratory bowl. During this interaction the film is physically removed from the "peaks" of the processed part and the "valleys" are unaffected. The chemically induced film re-forms only at the peaks that are interacting with the vibratory media, and the process repeats itself. Over time, the peaks are removed, leaving only the valleys, producing the improved micro finish. The second step is referred to as the "Burnish Process." After the required micro finish is achieved, a mild alkaline mixture is introduced. After a relatively short period a polished, chrome-like finish is produced. In addition to the polishing effects, this step effectively removes all traces of the film formation from the refinement process.
Also:
We hold the exclusive license from REM Chemicals, Inc. to offer Isotropic Finishing in Georgia. "PCMC" is the only Company in Georgia, and will be the only Company in Georgia, Licensed to provide this unique gear finishing service. We have obtained REM Chemicals State-Of-The-Art Equipment, Chemicals and Media.
CRYO-REM (R) IS A TRADEMARK OF EVANS PERFORMANCE PRODUCTS, LLC AND USED UNDER LICENSE BY PROFESSIONAL CRYOGENIC METALLURGY & COATINGS
