- Jun 5, 2019
The knife is a Spyderco Manix 2XL in S30V steel. I use my knife a lot at work, Mostly for opening boxes or caulk tubes but I also use it for cutting wood. It chipped very quickly after I began using it, I was cutting card board or wood at the time it chipped. I have resharpened it (wet stone and strop) and tried to put a little steeper bevel on it, but its chipped out again. There are a ton of smaller chips in the same area as well. The chips range in size from about 1/32 of inch deep and 3/32 long to barely visible. It effects about a 3/4 inch section of the blade, The rest of the blade cuts great and has no issues. I never had major issues with chipping on other pocket knives I have owned when used normally. Maybe I am to picky? Or should I send it in and get it looked at? Or different method of resharpening?
Also this is still a great knife despite the chipping, I have only used Kershaw and Gerber up to this point for pocket knives. This one far surpasses any pocket knife I have used in the quality of workmanship, materials used, and the thought that went into the design. I see why people spend money on expensive knifes now. Thanks for any advice.
