Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Most folks split wood green solely to speed up the drying process. Takes forever for a 2 foot diameter log to dry out whereas split into chunks it's ready to burn within a year!
Well put Old Axeman, well put indeed.And I thought today was New Years day not April Fools day.
" after a while I would stack two on top of each other and split them both at once. Or after splitting a log in half I would stand one half up, and lay the other half on it flat and split them both at once"
Really?
I've done those tricks before but it only works with clean wood in shorter lengths in species that split easily. If the wood is stringy then your splitter of choice needs to be at least moderately sharp, too, so it can get through any strings on its way through.
A pdf file of the book "Splitting Firewood", by David Tresemer, can be found here:
http://www.fastonline.org/CD3WD_40/JF/425/20-477.pdf
It's a interesting read, including a MythBusters-style chapter that examines 6 common myths about splitting firewood, and evaluates whether they are true or not.
Example: "Myth Number 1: Split from the bottom, not from the top."
"To test which way would be best, I got together thirty-six pairs
of billets, all sixteen inches long, to be split for stovewood. Each
pair was matched for species, diameter, knottiness. and number
of splits. The splitting of each billet was timed..."
You can find the results in the book.
From an interesting book called "Splitting Firewood" by David Tresemer:
"To summarize, it is best to fell trees between late autumn and early spring, to limb and buck them at that time, to split them in a week or two when check lines appear, then to stack and cover until the following fall or winter." [page 75]
We burned about 12-20 cords of wood per year in good ole Pa, and it is, again on average, easier to split wood that has dried, over green wood.
