First, if you are finding "rogue scratches" then you have not properly used the previous stones. It is not the stones fault you have left over scratches.
Second, don't get lost in thinking you need every specific stone someone mentions. You will be better served building a quality set of stones that suits your needs and adding as necessary. Like in my video (as I speak about below) my base for that sharpening consist of the Naniwa Chosera 400, 800 and 3000 and I add stones as necessary for the task. Having a bunch of different stones and trying to make it work is usually the road most go down before building a good base of stones that work. You need something consistent and it sounds like you are just grabbing at anything to fill the blank?
I just noticed your comment on my video (I'm MrEdgy) and Yes... Chosera stones finish better than other stones but like in the video I only go to 3k because Finer Chosera stones still make a fairly toothy edge and you need smooth with a razor. The Chosera stones and specifically the 400, 800 and 3000 set a great base for any polishing job from knives to razors and more because the scratch pattern these stones produce is simply superior to most other stones. I don't have the Snow white anymore... it cracked apart but I have wanted to get another Kitayama 8k as a replacement (I've had several before). The Kitayama is used by one of the big brands so I figured it would be a good choice, and I won't have to worry about it cracking.
There are some Chosera stones I do not recommend, like the 600 which I feel is pointless when the 400 is better in every way, and the 2k which is very hard and feels unpleasant to sharpen on. It's finish is also not nearly as good as the 3k. I would also completely stay away from Shaptons for razor honing, the 500 for setting a bevel might be ok but the finer grits are just not fine enough because the finish is more aggressive making for a very uncomfortable shave.
Personally, I was never a fan of the Naniwa SS to polish razors and the 12k is like an urban legend IMO, sounds awesome but is more meh. I'm also not one to go past 8k before switching to a strop. For stropping I like Chromium oxide on balsa wood as a pre-polish then a healthy amount of passes on a hanging strop. I find a hanging strop to be one of the best tools in razor honing, it produces a quality of shave I simply cannot get from a loaded strop.
