Here is something else for you to think about while you are reading and studying. If you are interested in the clay coating technique of heat treating, as the Japanese do it, they (the Japanese) traditionally use shallow hardening steels and quench in water, the blade is forged straight but comes out of the quench with the gradeful curve (sori) we all know in most (but ot all) Japanese blades. So the curve is induced by the quench. This is important because if what you want to do is Japanese style with lots of activity in the hamon then you will need to find a shallow hardening steel to use such as 1050 or 1060 or 1095.
Most modern factory produced steels have alloying elements, such as manganese, added to them to allow them to harden reliably and deeply in industrial situations. These steels are generally quenched in oil since a water quench causes too much of a shock to them and will often crack. These steels can be quenched in water but the risk is high. Now if you decide to do the Japanese style blade with a modern steel, with a clay coating, and quench in oil to be on the safe side, then what often happens on longer blades is a reversed curve, a curve downward toward the edge! Modern deep hardening steels also will not produce the depth and level of activity in the hamon, which is one of the nice by-products of the clay quench.
I know it seems a bit confusing but these are all elements, among others to keep in consideration.
