I found this in an attic. Any ideas what this is and how I could clean it up? I've heard hoppes 9 and fine grit sandpaper for the blade. What about the handle? Antique knife michigan
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Thank you. I love the old knife and I'd like to carry it!That's a cool find.
As previously recommended by others, I'd absolutely minimize or avoid entirely anything abrasive, like the sandpaper. The steel wool and oil/WD-40 scrubbing is about as much as I'd do to the blade, backspring or the iron bolsters. I'd personally hesitate to soak those old wooden handle covers in anything though, probably limiting anything there to some light rubbing with 2 - 3 drops of mineral oil or mineral spirits on a microfiber rag to clean it, and/or applying a wax.
That patina on the blade is bonafide antique and real character in itself. Took many decades at least, to form it, and it won't harm the steel at all. It'd be a shame to scrub that off. Just use the steel wool and oil/WD-40 to scrub away any red/brown rust and leave it at that.
By the way, since you'd asked in your original post as to what the pattern is, it looks like it was possibly used for electrical / cabling work. Those notches in the blade look like the insulation-stripping notches seen in more commonly seen electrician's pattern knives (often called 'TL-29' pattern, or 'radio' knife, or 'lineman' pattern), which usually have two (2) blades, one of which is a liner-locking screwdriver with a cable-stripping notch and a semi-sharpened edge, used for cutting into the insulation or jacketing around electrical wires or cabling. Normally the actual knife blade in those patterns is simply a spear pattern blade (as in yours), but without the notches in the cutting blade itself. I wouldn't know if yours was originally made with the notches as you found it, or perhaps it might've been a DIY modification to a more standard-pattern slipjoint knife, to do that sort of electrical / cabling work.Thank you. I love the old knife and I'd like to carry it!
