Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
(the best place to buy the EAB Lite is Amazon.)Damn you Amazon
The first part of your post is a given, but using my trusty Gerber is a good idea for sticky tape. Plus us Canadians use duct tape on everything which is even messier! Cheaper knife it is...Scientifically the only known method, once tape glue contamination has occurred, is to place the blade in a Bessemer furnace along with a pound or two of borax flux and stew until thoroughly thin and separated . . .then role the billet into blade stock and grind and heat treat to taste.
This is why I ALWAYS cut boxes with my loyal and lovely Gerber EAB Lite.
Lighter fluid works well without damaging the finish.
WD40 is my go to spray to remove sticky residue from anything metal.
Best solution I've ever used is Zippo Lighter fluid. It is also good for removing lubrication. It's also know as VM&P Naphtha.Hey all,
What are you using to clean packaging tape residue off your blades? I have a black coated G10 Spyderco that has the sticky crap all over it. Damn you Amazon!
What is the best solution to this problem that won’t discolour the blade?
Thanks!
