Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I'll have to let some just dry out on a sample bit and check to be sure. Can't see through the scales to check the currently dry stuffDoes it still have the tiny bubbles all through it when cured?
That is for "dampening"Interesting... "For non porous surfaces only" which would seem to take wood handle scales out of the running.
I use gorilla glue on my sheaths. Get the leather damp for forming, put a line of original gorilla glue around the edge (needs moisture to react/adhere properly anyway), clamp it fairly lightly, and then finish the edge on the belt grinder. Quick, easy, and produces an excellent simple sheath.
West systems might be worth trying. It's damn near water clear provided it doesn't sit around the shop for more than 3 years or so.Can you use coloring agents with it? ie epoxy dyes etc.
I love G-Flex but because it's amber it causes the white epoxy dye to come out off white.
It says it is for wood, glass, metal, foam, ceramic.
I don't know if the clear is a PU adhesive, but the Original Gorilla glue is and it out performed pretty much all epoxies for wood to metal IIRC the glue war conclusions. The problem was the foaming and the bubble in the glue line.I assume that is a polyurethane adhesive which is good for gap filling and a fairly reliable adhesive.
On the other hand, it does not have the strength of epoxy when trying to attach wood to steel. Even Elmers glue is stronger when attaching wood to wood. It has it's uses, but be sure to know what you are doing before using.
