    Price is $300 ea (shipped within CONUS). Now open to the forums as a whole. If you live outside the US, I will contact you after your order for extra shipping charges. If there are customs issues? On you.
    User Name
    Serial number request
CM154 vs ATS-34
Which one of these is the better blade. What is the designation for blade hardness from Hardest to weakest?
They are the same steel (although you may find slightly different elemental compositions on various charts); the difference is in that 154CM is cleaned by AOD (Argon Oxygen Decarburization), and thus is the cleaner steel of the two, which was not previously the case (AOD is a recently adopted procedure).
The surface hardness of steel is measured by the Rockwell C scale. This involves pressing a diamond penetrator ('brale') into the steel with a standard pressure, then measuring the indentation created.
For the technical details, go HERE
Click on technical information, then Rockwell Hardness.
Hope this helps, Walt
Good vs. bad heat treating will reveal more differences between these steels than the designation alone. My initial foray into the world of ATS-34 was strictly with Benchmades. This was strictly a hit or miss gamble. Some sucked, some were OK. I was not overly impressed, and pretty much learned to despise stainless in general. But if I was not seeing good results with my blades, why were so many custom makers using it? I have sinced learned through my experience with my MT's using similar 154-CM, and with multiple customs blades using ATS-34, is that I really like this steel. Much easier to sharpen and better edge holding as well.
Don't base a buying decision on steel type alone. But they both are generally better than 420
I have noticed that MT, Puma and MOD can get a 154CM blade WAY outperform ATS-34 by Benchmade and Gerber.
Though my BM ATS-34 blades have held up very well...
Wayne.
"To strive to seek to find and not to yield"
Tennyson
Ranger motto
A few useful details on UK laws and some nice reviews!
http://members.aol.com/knivesuk/
Certified steel snob!
