- Aug 12, 2006
Well the CS Magnum Kukri machete I bought a few months back finally got a work out.
My moms place was getting over run by burrs and thistles and out of 10 acres 1 1/2 was pretty bad.
I started with a two handed old fashioned scythe but found that it needs a bit of space to work and had a bit of trouble hitting the 2-3 inch thick stalks of large burr bushes, it zipped thru thistles like crazy tho.
So out came the Magnum Kukri
The handle gave no blisters over about 5 hours of heavy use although I did use gloves (probably a bit abrasive for non glove extended use will likely wear in though). Nice secure grip, never felt like I was going to have it fly away.
I started with the blade edge stock (very rough ) it cut "okay", after a few hours gave it a free hand touch up with single cut file and it began cutting "well" on the thistles and burrs. I am sure with a bit more work I could get this cutting "good" to "excellent"
I swapped with my brother for his 20ish inch Gavillan machete and preffered the cold steal Magnum Kuk.
The Cold Steal machete material seems quite tough, I dinged numerous rocks , a brick, and a barn foundation with very little blade damage ( expected much worse after each impact) , what little damage came out easily with the file.
I discovered the Kuk shape to make a nice "brush hook" when flipped over for carrying burr bushes to the burn pile , saved me getting my hands in them and the back from less bending over.
The cordura sheath is a waste of hair and teeth.
Overall the CS Magnum Kuk impressed me for the 20 odd bucks I paid and its performance over a heavy 5 hour use session to the point I plan on buying another for the truck, will just need to build a decent sheath for it.
A
A
