Don't have a whole lot of options available in the CS Recon price range (live in South Africa) hence considering the Recon. The BK9 bit on the expensive side for the intended purpose. I own an ESEE 4, but blade not long enough and don't want to abuse the blade for the intended purpose the Recon would be used for.
What brands are you able to get your hands on down there? That might help us guide you to a solution.
But, the CS recon would work. Long term, it may not be the best and the narrow blade height wouldn't be my 1st choice for sure. They can transmit a lot of shock to the hand, in my experience.
A condor bush parang would be high on my list.
Are European brands reasonably priced over there? There are a few options there that might be worth looking into.
How is shipping from Nepal? There be some good options from the kuhkri guys out there, Himalayan imports and Kailash blades in particular. I don't like batoning with the kuhkris but they can split wood like an axe or they have more standard, knife-like models available using a very tough steel and very tough heat treat that would serve that task really well, assuming the price is good. Both have budget options with a lower level of fit and finish and materials but they still function really well.
Another idea might be to just get a kitchen cleaver that has the appropriate length and use that. Baryonyx has a few cleaver-like knives aimed at wood processing but shipping is probably going to be cost prohibitive for you unless there's a local supplier for you.
This one is nick named the "kindling kleaver", as one example. There are a few different offerings that they have.
www.baryonyxknife.com
Here's another
Also, look into a Japanese Nada style blade. They seem to be right in line for the task your after (no idea what you can get there and at what prices).
