Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
That's the one, I'd like to take it hunting but I don't think the factory sheath is up to snuff.
This is a knife i paid $19 for. I'm open to leather as well but truthfully I'm looking for the cheapest option that will do the job.Good knives deserve good leather sheaths (Kydex sucks). Have one of the great leather craftsmen here make one up for you, or make one yourself.
Leather is generally more flexible and forgiving than kydex .This is a knife i paid $19 for. I'm open to leather as well but truthfully I'm looking for the cheapest option that will do the job.
Hmmm, I've got a Scalper and a Kabar USMC with a leather sheath. I'll try to remember to test this out tonight and post results.I think it’s too big for a 119 sheath. The kabar might work but I sold mine and can’t test fit. I’d look for an aftermarket nylon/cordura sheath, though the factory sheath is good to go in my opinion.
1.4" wide 6" longhow wide and long is this knife blade? Wonder if a kabar leather sheath would work. I've stuck many knives in those with good results?
looked it up see 6" blade. maybe a Buck 119 sheath would fit if handle isn't too wide to snap it shut, and blade isn't too wide to fit in the sheath?
nice. thanks for testing it. I'm often amazed at how many knives a kabar sheath will kinda fit. not perfect, but good enoughWell I'll be damned.
The snap didn't quite close, but I probably could have forced it if I really tried. There is a little extra room near the tip so you could feasibly cut a little slot at the throat to make the guard fit flush.
sorry I have the sheath, but not that knife. can't test it but oldmanwilly did. he thinks he could stretch the leather strap to close the snap. so not perfect but enough it could be used, it appears.1.4" wide 6" long
Thanks for testing it out. Much obliged Sir.Well I'll be damned.
glad it worked out, just be careful of your fingers on the bit of exposed blade. looks small area but nothing worse than cuts out in the jungle.......I ended up fighting a Ka-Bar sheath localy (Navy version if that makes a difference). The fit is great and the clasp on mine closes easily. Thanks again for the suggestion.
What's wrong with the original sheath?A shot in the dark but would anyone know of an aftermarket kydex sheat that would fit the Cold Steel Scalper Knife? Cheers!
That's it. The cost of a new sheath is wortth the piece of mind for me.Not the OP, but I find the original sheath to be pretty decent for what it is (a Mora style plastic pouch). Doesn’t dull the edge and definitely can’t allow the blade to poke through.
A concern I’d have using it for hiking or hunting would be that it’s possible for the belt loop to open enough that the sheath slides off the belt, as it doesn’t have a ton of tension keeping it closed.
