- Feb 24, 2001
Hi folks.
I am thinking about getting "The Spike" by Cold Steel (the clip-point type, not the tanto). I read a description that says it is "distal tapered and flat ground to a zero edge." I'm pretty sure that I understand what the flat grind means, and even distal tapering. I just am not sure I would know how to sharpen such a knife -- and I don't believe in buying a knife until I know I'll be able to keep it sharp on my own.
Does "zero edge" mean that there is no bevel at the cutting edge -- that the flat of each side of the blade goes right to the cutting edge? I hope not. It sounds in such a case that the knife would have to be sharpened by grinding at a 0-degree angle right along the flat of the knife. That can't be, can it?
If I could be sure that there is some sort of normal bevel to the knife's edge, I'd probably buy it; but as this is a potential Ebay transaction, I don't have the benefit of being able to hold and examine the knife. Suggestions? Input? Thanks.
