Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
i just got a Cold Steel Golden Eye Elite Folder. I really like the knife in every way except for how stiff the lock is and how hard it makes it to disengage. Can it be adjusted to soften it a little? Will it soften up over time....with use?
My counterpoint xl so was also particularly stiff, even for a triad. But with no autolawks, I cant quite say it was a virtual fixed bladeI have a Counter Point XL that becomes a virtual fixed blade when wrist flicked open! You have to depress the lock by pressing the torsion bar against the edge of a table to unlock it. This is no exaggeration. But opening the knife slowly using the thumb post or two handed and closing it becomes manageable. I did the whole leaving it open at 45 degrees when not in use and it helped but didn't completely solve the lock stiffness.
This is what I did with the aus8 recon1 I had. Worked great. Didn't need to do it on the xhp version.You can also disassemble it and lower the spring tension slightly. I've done it before and it works like a charm.
This is what I have done on several.how stiff the lock is and how hard it makes it to disengage. Can it be adjusted to soften it a little? Will it soften up over time....with use?
My first Cold Steel, a Mini Tuff Lite was so dambed difficult I could not unlock it with my thumb period I had to cram my finger knuckle against the lock bar to budge the thing. That's what got me looking for solutions.I own many a Tri-ad lock and I've never had a problem, my Recon1 XL had a little stiffness but the leaving it open trick helped.
