Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Hi folks, since getting this I've posted up a few images around, hard not to when you like something but wanted to post this short review of the folder.
As the title suggests, this is about the Cold Steel Ultimate Hunter for 2015 in CTS XHP steel and G10, more smooth than the heavy texture we were use to on their knives.
Closed length 5"
Blade length 3 1/2"
Blade thickness approx. 3mm
Steel CTS XHP
Flat ground, fairly high grind, edge down to a thin cutting edge, don't have the edge bevel thickness...I'm sorry, but my calipers' battery died...didn't even know it was sick!
Handle scales G10 with a bead blasted type finish
They provide TWO clips but one set of screws, since the clips are handed, you need one for left or right side carry.
Handle thickness across the spine approx. .6"
Closed widest portion including the spine of the blade approx. 1.6"
Lock mech, none other than the infamous Tri-Ad locking system, locks up like a bank vault!
Handle has an anodized aluminum back spacer that is set in at the very end of the knife
Handle includes a lanyard hole, large enough for paracord to easily fit through.
Now the fit and finish of this folder is remarkable, very well done all around. It is made in Taiwan and they really have stepped up their game on this folder. The blade arrived shaving sharp and one test I give a knife is to see if it will push cut down through certain material, such as phone book spines, or q-tip shafts and this did both easily. Cardboard of course was a breeze to slice through. While the tip is pretty rounded, not an exceptional piercing type blade, it's intention is to be used as a hunter, hence the name. Which by the way I'm not a hunter and sometime down the road may well sand off that name on the blade. But if I need a very fine tipped knife to pick splinters out, I always carry a small traditional on me that will handle such a chore. While open, there is absolutely no blade play what so ever, it is a very solid locking folder mechanism and also unlocks without difficulty, you do need to press down hard, but you'd want that security too.
The handle, it's length and lack of multiple finger choils makes it easier to grip in a wider variety of positions and overall feels very comfortable and provides a confidence when in use. I did notice that when I had washed the knife, it was harder to thumb open the blade, the water making it a bit slippery, might take and make the thumbstud a little more coarse to help in opening. I have seen videos of some of you guys that have 'super' thumbs and flick these things open, that ain't me, so I thumb this one open in the traditional sense.
I prefer to think of this as a very No Nonsense kind of folder, even if it has a pretentious sounding name you can see that I'm serious about sanding off the name eh? But it may very well be the "Ultimate Hunter" so that probably was a good name for it.
So this one gets the G2 approval, will she stay in the fold long? man I wish I could tell you yes without hesitation, but knowing my track record as most of you do, it is very hard to say, at the moment, I don't see her leaving this house, except clipped to my front right pocket, for a long time.
Here are some images of the knife that I took the other night, I've added a paracord, as I do on most of my knives, a diamond knot about an inch from the end aids in drawing the knife from the pocket hooking my pinky around the knot, the black thread is a whipping knot that ties the two paracords together, helping to keep it from moving into the path of the blade. The lanyard continues out for 6" and ends in another diamond knot.
Enjoy folks and grab one while you can.
G2
Closed length 5"
Blade length 3 1/2"
Steel CTS XHP
G2
